Vacuum actuator valve.
Old Jan 2, 2016 | 09:41 AM
Zoix's Avatar
Zoix
Default Vacuum actuator valve.
I believe I have a bad actuator valve here's why. When I put vacuum to the valve through the yellow supply port with no vacuum to the white control port I should have vacuum through the green open port. I can not build vacuum through the green port so I believe the actuator valve is leaking. When I put air through the yellow port and plug the green port the air leaks out the exhaust. Do I need a new valve?
Old Jan 2, 2016 | 09:55 AM
C3Hawk's Avatar
C3Hawk
You may be right!
Here is a link to a tutorial I wrote a while back about testing these relays:
https://www.corvetteforum.com/forums...s-of-pics.html
I believe this method is the only way to be sure.
Good luck!
Old Jan 2, 2016 | 10:01 AM
SwampeastMike's Avatar
SwampeastMike
You have to block the green port (a finger will do) while you apply vacuum to the yellow. It should then maintain vacuum indefinitely.
Next apply vacuum to the white port and release. Do this a few times. You should hear a piece inside move when you release the vacuum.
Finally put a tube to the white port and apply vacuum. Clamp the tube fully shut. Block the red port and apply vacuum to the yellow. It should maintain vacuum indefinitely.
Old Jan 2, 2016 | 11:01 AM
Zoix's Avatar
Zoix
Default Vac valve
Thanks for the replies. I need a new valve.
Old Jan 2, 2016 | 01:20 PM
Dave J's Avatar
Dave J
If your top control chamber is holding vacuum and lifting the internal piston you need a new piston unless you want a repop relay. Here's a couple of videos I've done on how I test my relays. If you are interested in having your original one rebuilt, let me know.
Old Jan 2, 2016 | 04:07 PM
Zoix's Avatar
Zoix
Default Vac relay test
Dave J
Thanks yes I did the test and the valve will not hold vacuum. I have ordered (2) from Bairs. Repops to be sure. I'll keep my fingers crossed that they are good.
Old Jan 3, 2016 | 10:44 AM
jrdestar's Avatar
jrdestar
Originally Posted by Zoix
Dave J
Don't waste your time and money on repops, Send your originals to Dave and let him rebuild them, I did and they work Great. Thanks again Dave
John
To Vacuum actuator valve.
