door alignment wedge fiasco
Ouch, sorry to see your door alignment wedge problem. Not that that it will help you now, but hopefully someone else may benefit, you had the pieces reversed. The plastic piece goes on door surround and the metal wedge on the door.
The 68 wedge design was bad because you can easily do what you did. If you want to use the wedges you might want to consider using the 69 design. The plastic piece was the same but the wedge was larger to insure it didn't over run the block.
John
John
Thanks. I was not sure which piece went where. The best photo I had looked like the way I installed them- but I was still guessing. For the 69 design, are the holes used those two rivet holes on the 68 or are new holes drilled? I'd like to use something to decrease the door rattle when the car is driven. RA
I can't do a direct comparison between my 68 and 69 as the 68 is in a storage facility right now.
The position of the plastic wedges on the door appear to be a little different between the years. They give some position dimensions in the 68 AIM but only say drill on dimples in the 69.
I took some pictures of my 69 and put down some rough dimensions. The up and down dimension position on the plastic wedges varied from 1.3 on the passenger to 1.6 on the drivers side. The metal wedges on the door were both approximately 2.375 up from the center of the top door lock bolt.
Sorry from the crappy cell phone pictures but it's all I have right now.
John
I realize you don't want to hear this but you REALLY need to have the Assembly Manual in front of you when you're working on your car. (It sounds like you don't have one.)
People make fun of it and say it's inaccurate and difficult to understand but it will SAVE you from things like this.
Another suggestion, I encourage you to get the parts catalogues from ZIP Corvette Products, Corvette Central, and Paragon Corvette Reproductions.
These catalogues OFTEN show a drawing (from the AIM) of the part installed so you'll have some idea if it's the part you think it is and if it installs the way you think it does.
I've been playing with the same car for 25 years and I still use those 3 catalogues and the AIM constantly.
I'm sorry for your troubles!
Regards,
Alan
Regards,
Alan
Well at least you have the AIM.
I don't have a copy of the 68 AIM so I can only give you a hint about where to look.
In my 71 AIM the info is in UPC 1 asm, Sheets F 1,F 2, etc.
These pages have to do with the installation of the soft top, the soft top hardware on the body, the soft top weatherstripping, and the soft top 'lid'.
The information on the wedge on the body (lock pillar) (which is very different by 71, or I'd gladly send you the page) is found on Sheet F4, Lid Striker, etc.
Look in that vicinity in your 68 AIM. There's also some information in the door section on Sheet K7 about the wedge on the door
It COULD be that the info isn't there, or isn't accurate since it appears getting the convertible doors to not shake was a problem that took some on going 'fixes'.
I guess this is the sort of thing that causes people with 68 cars to say how frustrating working on them can be…. continuing changes and or inaccurate information!
Believe me, if I had something to help you I'd send it, but I don't.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
I really depended on the AIM when I began working on my car almost 25 years ago. Back then there was NO internet so there weren't many sources for help. So I HAD to learn to use it.
The AIM can be VERY difficult to find things in, and understanding the drawings be a puzzle, but it's still the best single source of information.
Regards,
Alan
Good Luck!
Regards,
Alan
Jeff
The wedges you ordered (the ones pictured above), are not 69 door alignment wedges. The ones pictured are the lock pillar wedges, and they will not work to align the doors on a 68.
The lock pillar wedges go on the top of the lock pillar, next to the small lock pillar weatherstrip. This is the little piece of weatherstrip that fills the space on the body, between the weatherstrip at the top of the door, and the deck lid weatherstrip. On 68's and most 69's, that wedge is soft rubber, and molded as part of the lock pillar weatherstrip. On late 69's through 75, the "soft" wedge was eliminated from the weatherstrip, and replaced with the hard plastic wedges. The hard plastic wedges are installed along side of the lock pillar weatherstrip.
69's used the same rectangular plastic wedges on the body (the ones you installed on the doors), as the 68's. The long brass wedges were installed on the door, instead of the small metal rectangular ones.
If you want to use 69 style wedges, on your 68, the brass 69 wedges are available. The brass wedges sell for $35 each, and you should already have the plastic wedges,m from your 68 alignment wedge kit.
And just in case...you are aware that the third photo is POST#1...you might want to replace the screws so the heads are not sticking out. The screws should be flush and tapered like what you show in the second photo in POST#1.
DUB
DUB
When I raise up the rear of a Corvette I get it in the center of the differential....and NORMALLY I do not do this ( but only under specific repairs)...but in a case like this...I would place two jack stands at the end of the frame at the end of the rocker panel in front of the rear wheel)...and when I lower my floor jack...I can see the gap widen....sometimes so much I have to stop because I feel the car is going to snap in half. And yes...the convertible top is down.
DUB
DUB
I also noted that you used rounded head Phillips screws to secure the wedge to the body.
My orig. 68 has counter sunk wedges and counter sunk screws.
It may just be enough to prevent or cause the type of problem you have.
My 68 had a drivers side on the body brass wedge snapped in half.
I replaced it with same and no problems.
I left the older plastic pieces on the door in place as all fine there.
Hope this small observation helped.
Marshal
