Cam Recommendations
Old Feb 3, 2016 | 01:47 PM
  #41
AboveTheLogic's Avatar
AboveTheLogic
Ughhhhh see what I mean?
So I need to return the bronze gear and bronze tipped rod and spring for the composite gear and locate a roller tipped or poly pump rod?
On summit, comp has a $16 bronze tip rod (the one I ordered), and a $121 roller tip rod. The composite gear is $105 vs the $55 bronze gear, and the composite gear says it is not for use with high volume or high pressure oil pumps (I have a standard oil pump). The bronze gear does say in its description that it is not intended for extended street use. I missed that detail.
What a headache.
Old Feb 3, 2016 | 02:00 PM
  #42
bluedawg's Avatar
bluedawg
Originally Posted by AboveTheLogic
Yeah I forgot to mention the push rods, those too.
A former engine builder buddy of mine saw my components (comp roller cam) and confirmed that I need the bronze distributor gear and pump rod since the comp cam is hardened steel (or whatever it was that he said). The gear was $55 and the rod was $17. The composite gear is over $100 IIRC.
Anyways, this all confirms my point. Lots to think about and understand, and misinformation to weed through, when going to a retro roller setup. Probably best to talk it out with the cam manufacturer.
Unless you ordered a billet camshaft the distributor gear should be cast iron, but with that being said error to the side caution, the composite gear and rod are cheaper, the roller rod cost more, but I figured that the pressure applied from the higher flow fuel pump would wear the composite rod out and I've seen multiple posts about the brass tip rods wearing some and starting to hammer and mushroom out to the point that they were a pain in the *** to get out, so the roller tip made the most sense.
Old Feb 3, 2016 | 02:04 PM
  #43
AboveTheLogic
The price of a roller tip rod is up there with the price of a new electric fuel pump.
Old Feb 3, 2016 | 03:33 PM
  #44
cv67's Avatar
cv67
St. Jude Donor '05
I run a carter 172gph mech fuel pump composite rod no issues fwiw
x2 on nixing the bronze gear for street use
Old Feb 3, 2016 | 03:51 PM
  #45
REELAV8R's Avatar
REELAV8R
This is the one I'm using. Been in there for 4500 miles or so no issues.
http://www.summitracing.com/parts/hrs-94475/overview/
For HEI gear recommendation ask the cam company. They should know what is compatible with the gear on the cam.
Old Feb 3, 2016 | 03:58 PM
  #46
AboveTheLogic
Thanks for the link! I sent a message to comp to find out about the distributor gear.
Old Feb 3, 2016 | 04:03 PM
  #47
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I run the poly fuel pump rod with a Holley 110 gph pump. No issues so far but only a few thousand miles on them. I also had the poly dist'r gear on my hei. No sign of any wear whatsoever after the same mileage already mentioned. I now have a fully programmable Mallory dist'r which is awesome thus far for playing with timing curves. Summit has a great deal on these dist'rs now because MSD bought out Mallory and they aren't made anymore.
Old Feb 3, 2016 | 04:50 PM
  #48
gkull's Avatar
gkull
I switch my polymer fuel pump rod between my two vette motors. so who knows it might have over 50,000 miles on it and I think 6 motors because of frequent refresh rebuilds.
I did not run a roller tip rod because they were new at the time and heavy. I had some concerns about the fuel pumps springs ability to function with a heavy roller tip when the motor regularly exceeds 7000 rpm. Some body mentioned that they use the Howards in their circle track 8600 rpm motors with stock type fuel pumps
Old Feb 3, 2016 | 05:08 PM
  #49
AboveTheLogic
I'll go with that howards rod and send back the bronze tip rod that is en route to me now.
Still waiting to hear back from COMP about the distributor gear compatibility.
OP sorry for hijacking the thread, but hopefully this all helps you with your decision!
Old Feb 3, 2016 | 06:05 PM
  #50
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by gkull
don't assemble a street motor with bronze parts
comp cams told me many years ago to run their bronze tipped fuel pump rod. what they didn't tell me is Don't expect it to last 4000 miles! So I'm driving down the freeway and my motor starts hacking and wheezing. I had a fuel pressure gauge on my duel feed inlet and the pressure wasn't even one psi. it could idle and drive really slow so i limped it to a friends house. I got a ride and bought a new ACdelco stock type return pump. the new pump put out the same psi. I was scratching my head. Well I called a friend and he said that the new comp cams were some kind of Austempered (SP?) iron that were prone to failure and maybe your cam lobe for the fuel pump rod is worn away. I was less than 3500 miles or something. So I tailored it home and confirmed the rod had very little travel rotating the motor by hand. So I yanked the motor out and the cam was ruined. But the worst part is I could NOT pull the bronze tipped pump rod out. The tip was about gone and had mushroomed. Making it bigger diameter than the hole. I had to use a small air dremmel to grind it back to round to get it out of the block. I was so pissed at Comp Cams.
30 years ago we all ran bronze dizzy gears in our sprint cars. It was an item that we checked and replaced often.
Roller tipped or poly pump rods are the only way to go
Roller tipped, mine still clicking and after checking a few times seems like it will keep on ticking. As for bronze, no need to use it these days, when billet cams first came out the whole cam was billet steel and would eat cast parts.
Nowadays it is more common to see a billet solid roller with a pressed on iron gear than it is to see without, times change and the old stuff is easily replaced with modern close tolerance machining of today.
Old Feb 4, 2016 | 04:06 PM
  #51
AboveTheLogic
COMP replied to my question and confirmed that my XR276HR is compatible with the stock distributor gear.
Old Feb 4, 2016 | 04:31 PM
  #52
TedH's Avatar
TedH
I ran a Crane Energizer 272-H10 grind with both 3.07 with TH350 and 3.54 diff with 700R4.
This is an excellent TORQUE cam and it was a blast. It is also very close to what used to be referred to as an 'RV cam'. I would recommend it.
As an aside, when I went roller, I kept duration pretty close to this cam but with greater lift inherent with the roller. As a result, the road manners are nearly identical but the engine pulls much longer than before (more middle and upper rpm power). Also, I did not have to adjust carb, initial timing or total advance. I would choose EITHER cam again and again.
Old Feb 14, 2016 | 01:49 PM
  #53
Doc Willie's Avatar
Doc Willie
No problem. I'm looking to build up an engine from a bare block at some point, just for fun. I'll definitely be looking at rollers then. For this swap, I'm pretty set on keeping it simple with a flat tappet but I think I've found a good solution. Howards has a cam that looks like it'll be a perfect match for the application.
