Door Realignment
Old Jan 5, 2016 | 03:10 AM
nz corvette's Avatar
nz corvette
Default Door Realignment
Hi Guys, Not sure if my cars RH door was fitted as a "Friday night special" back in 77 but it didn't fit that well(see pics)
So I finally decided to change the door shims and pins, pins are quite straight forward done that on the other side but I wanted a better way to remove and hold the door, so I used a bike jack/ramp with a couple of mods(more pics)
Just as well! I had to pull the door on and off 3 times to get the shims to fit, took 1 off the top hinge and added 2 to the bottom, while not perfect (they never were)better than before
Cheers Dave
All Good from down under
Old Jan 5, 2016 | 06:45 AM
Alan 71's Avatar
Alan 71
Hi Dave,
Quite a nice set up you put together to handle the weight of the door!
AND, quite an improvement in the fit!!
You must be pleased with the results!!!
Regards,
Alan
Old Jan 5, 2016 | 09:07 AM
454Luvr's Avatar
454Luvr
It's great to see this kind of ingenuity. Excellent job on the door!
Old Jan 5, 2016 | 09:18 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Very well done! I used my son when I replaced my hinge bushings but I think your setup is more reliable
Old Jan 5, 2016 | 06:29 PM
SB64's Avatar
SB64
Default Door hinge
Nice job and a nice jig. Did something similar when I did my doors. Wood comes in handy sometimes.
ZIO
Old Jan 5, 2016 | 11:15 PM
69FASTFUN's Avatar
69FASTFUN
Might just have to borrow your idea
FF
Old Jan 6, 2016 | 02:53 AM
nz corvette
Hi Guys, Thanks, yep real happy with the end result its amazing what you can do if you think long and hard enough
Dave
To Door Realignment
