DAMN !!!!!!!!
Old Aug 29, 2002 | 07:54 PM
ksems's Avatar
ksems
Default DAMN !!!!!!!!
hi all -
third and last post hopefully on my AC
no good news.....
The Compressor ( Factory Air ) is junk....:mad:
No AC coming home :mad:
I tapped the clutch with a stick while the car was running and it
kicked right in......so the mechanic and I figure that the compressor is bad ...its also making noise....:(
so now ...another $260 for a AC delco compressor and another $200 to flush and fill again.....
I am totally spent....
I also need 4 new tires.....
car goes in the shop................for the 4th time
[Modified by ksems, 5:54 PM 8/29/2002]
Old Aug 29, 2002 | 08:33 PM
MY63Z11's Avatar
MY63Z11
Default Re: DAMN !!!!!!!! (ksems)
hang in there you almost got it licked :cheers:
Old Aug 29, 2002 | 08:38 PM
Armstrong's Avatar
Armstrong
Count yourself lucky that your almost there. I still have a long way to go before I'm ready to tackle my a/c. Good luck and I hope it turns out good next time. :yesnod:
Old Aug 29, 2002 | 09:52 PM
73454's Avatar
73454
Have you considered replacing the A/C with an aftermarket set up?
I don't use mine (pulled it out), but as I understand it these cars do not have the most reliable A/C systems and an aftermarket unit may be the most practical choice.
Just a thought...
Old Aug 29, 2002 | 11:25 PM
Alwyn678's Avatar
Alwyn678
Default Re: DAMN !!!!!!!! (73454)
Chunk the ac......It is a dead boat anchor anyway......Go Faster and let the top down :jester ....Mine is sitting on the work bench :D
To DAMN !!!!!!!!
