tpi to old stuff
Old Jan 12, 2016 | 06:05 PM
cdw's Avatar
cdw
Default tpi to old stuff
have a chance to get a tpi from 92 firebird 350 less dizzy and harness. i noticed that the center bolt holes are of the vortec type,so without the dizzy and harness and what looks like work needs to be done on the intake will this be a pita to convert to my 388 sbc. will an older tpi intake with the conventional bolt pattern for older heads work? don't want to sink a ton of money into this swap as i have some nice old school intakes and holley and q-jet carbs. thanks
Old Jan 12, 2016 | 06:17 PM
7t9l82's Avatar
7t9l82
They start running out of power about 4500 to 5000 r.p.m and with a 383 it may be lower than that.it's so out of date guys that converted to it 20 yrs ago are going other directions. I wouldn't sink alot of money into one.
What I think you have is the later version that has the l98 heads they have those bolts arranged that way.they don't have vortec ports.
Alot of people have converted to them so it can be done, but I think there are better options.
Old Jan 12, 2016 | 06:30 PM
toobroketoretire's Avatar
toobroketoretire
The Tuned Port Injection systems were designed for the smaller 305's and were never meant to be used on the larger 350's and that's why they run out of breath around 4000 rpm. If you bought the larger diameter aftermarket runners it would work okay for a 383" up to about 6000 rpm if you had enough camshaft to support 6000 rpm.
Old Jan 12, 2016 | 06:45 PM
Shark Racer's Avatar
Shark Racer
IOW TPIs are perfect for cars that don't run headers(which make power from 4000 to five million RPM).
Honestly though, the TPI is a good match for a relatively stock L-48 build. The computers are pretty archaic - but there's kits out there to control TPI, or you can roll your own.
If you want it to support big RPM, you're going to be spending enough bucks that you're better off just going a different path.
Old Jan 12, 2016 | 07:34 PM
mrvette's Avatar
mrvette
Did my TPI on L48 stock engine '72 vette in '95 the changes here in Florida have been done many years ago....L98 engine, LT1 with HEI thanks to a TIG welder buddy.....the computer is still speed density, as fail to see the need for any 'upgrade'.....
NOW having some $$$ and being younger, yeh, a LS conversion would be in line.....but car runs fine, so leave well enough alone....
age 71 and arthritic as hell.....
Old Jan 12, 2016 | 07:49 PM
anesthes's Avatar
anesthes
Actually it's due to the length of the runner and the harmonic wave it performs in. The 305 vs 350 is irrelevant, and it's an old wives tale.
-- Joe
Old Jan 12, 2016 | 08:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
383 with a TPi is a bad idea period at least put a converted LT1 intake on it should clear the hood fine and can still make a little power.
Old Jan 12, 2016 | 09:01 PM
Kacyc3's Avatar
Kacyc3
depending on the price and what you have the heads might be an upgrade, not the hottest heads on the market. i have a set on my 406 because it came with them.
Old Jan 13, 2016 | 10:45 AM
anesthes's Avatar
anesthes
Couple for sale on TGO for like $350.
Minirams come up daily as well on ebay for under a grand.
-- Joe
Old Jan 13, 2016 | 11:41 AM
cdw's Avatar
cdw
Default tpi
thanks for all the replies
  • . cam is crower solid lift .458 in.468 ex 230,236 dur at .050. crower s
ays 2-6 groad. heads are pro comp electronics iron 1.94-1.50. 58cc compression about 10:1 i live in the country and this engine will be my toy for short burst in the afternoon and evenings. i would like max. rpm about 5500 and that might be just a little high for me. 3:73 with built 2004r.its a trade for one of my turbo 350s, so no funds will change hands. i have been a carb. guy my whole life and thought i might mess with tpi a little.i know i will have to educate myself. i noticed the heads have a dual bolt pattern with the new type bolt holes on each end but no center new type.the guy said no dizzy and computer had the wires cut off at the connection.that sounds bad to me.as i said before,not past 5500. might be fun to try. thanks guys i
Old Jan 13, 2016 | 12:08 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
-- Joe
This is exactly right......team that with smallish diameter individual runners and it is what it is.......
SLP sold for years Siamese Runners to dramatically improve top end flow....but this requires plenum mods on the Throttle Body end and the entrance of the runners to be effective...as well as opening up the base or using the Edelbrock base.....
Maximum effective power with this unit is about 425......
They ARE very simple and reliable though......and look cool.....
Jebby
Old Jan 13, 2016 | 12:41 PM
cdw's Avatar
cdw
Default tpi
thanks for the reply. cool and simple and reliable is what i'm after.if and when i start to mess with the tpi i'm not going to drop a bunch of money into it. i planned on using the setup just the way it came off the bird with maybe some injector upgrades if needed.
Jebby
Old Jan 13, 2016 | 10:14 PM
Kacyc3's Avatar
Kacyc3
the problem with trying to learn EFI with a TPI car is that the ECM is PROM
(Program read only Memory) meaning you have to use pre programed chips.
At a minimum I would do a kit like this and pm a guy on chevytalk.com for the auto tune program he wrote or you will have a difficult time learning to tune your car from scratch.
http://www.ebay.com/itm/Holley-Marin...5WlIVM&vxp=mtr
Old Jan 14, 2016 | 12:05 AM
Shark Racer
Moates has good stuff for programming. Reflashable PROM adapters as well as emulators which will act like the PROM and allow real-time adjustment of parameters.
Still an archaic ECU, though.
Old Jan 14, 2016 | 06:57 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Here is some excellent info.....
They sell everything you need as well:
http://www.hotrodlane.cc/NewTPI%20links%20page/TPI%20links%20page.html#tpitech
These were the first stand alone harnesses that I know of....and were a staple in the high dollar street rod community for many years.....
Jebby
Old Jan 14, 2016 | 07:22 AM
Rotonda's Avatar
Rotonda
The runners are only part of the story. The real problem is in the stock intake manifold they bolt to - the passages in this are small and restrictive.
While TPI will never be a high RPM system - it was designed to produce torque - the entire system can be tremendously improved by adding vortec style heads and a TPI manifold designed for these heads (Scroggins-Dickey). These changes combined with larger tubes. cam and bigger throttle body will produce a smooth running easy starting torque monster for the street - happy at lower RPMs, quiet and much more responsive than a carb engine.
Old Jan 14, 2016 | 09:07 AM
anesthes's Avatar
anesthes
I used an ROM emulator for about 10 years. But the functionality of the stock stuff, even with patches got too limited.
I've been using a Megasquirt ECM for the past couple of years, and it's quite fantastic. Will run a TPI, LT1, LS1, just about any trigger method.
-- Joe
To tpi to old stuff
