Wrong Shift Rods
Old Jan 13, 2016 | 06:21 AM
Too Slow '90's Avatar
Too Slow '90
Default Wrong Shift Rods
I purchased a shifter assembly with the rods pictured below. They are supposed to be for a Muncie however the slots in the brackets (where they attach to the trans) are not long enough. Do I have the incorrect brackets for the trans? If so where can I get the correct ones? Thanks.
Old Jan 13, 2016 | 11:25 AM
oledave60's Avatar
oledave60
Muncies before 1969 used the levers like in your picture and were attached with a nut to a stud, In 1969 they changed to a bolt mount and that must be what your trans has. The slot is a different size and the older levers will not fit the newer style, but the newer style will fit the older trans with an adapter.
Old Jan 13, 2016 | 11:56 AM
Too Slow '90
Thanks for your help.
Old Jan 13, 2016 | 01:27 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
BTW TooSLow. You can get new shift shafts (the part in the trans) from one of the Muncie parts vendors. If you cant find the right levers
Old Jan 13, 2016 | 03:37 PM
7T1vette's Avatar
7T1vette
I do not have one to know for sure BUT...
Not sure why you couldn't just make larger openings in those arms using a Dremel.
Old Jan 13, 2016 | 04:07 PM
oledave60's Avatar
oledave60
I guess you could, but they are hardened steel and nearly impossible to drill through.
Old Jan 13, 2016 | 05:26 PM
Too Slow '90
That's the approach to start. Nothing to lose if it does not work.
Old Jan 13, 2016 | 05:55 PM
gbvette62's Avatar
gbvette62
Volunteer Products makes all of the 64-81 levers, as well as complete linkage kits. The 69-73 1-2 and 3-4 levers sell for $10 each, and the reverse lever is $15. For $69 you can get a complete new linkage set, with correct levers, rods, nuts, bolts, clevis, swivel, etc.
Old Jan 13, 2016 | 07:57 PM
oledave60's Avatar
oledave60
^^ that's what I did with my 73 Camaro swap and it was well worth it.
Old Jan 14, 2016 | 06:35 AM
Too Slow '90
I may have to go that route. I am going to try a little tweaking first and see. It was originally a manual car that someone converted to auto so I did not have anything to start with when making the change back. I thought I had purchased the correct components but I guess not. Thanks for your help.
To Wrong Shift Rods
