A/C Question
Old Jan 14, 2016 | 09:00 AM
Buickbob's Avatar
Buickbob
Default A/C Question
I purchased the complete A/C system from a 1977 corvette. Will it fit and work in a 1970 Coupe?
Are there any good installation instructions around for installing it.
I hope I haven't chewed off more than I can chew.
Thanks For any help!
Old Jan 14, 2016 | 10:31 AM
Tampa Jerry's Avatar
Tampa Jerry
Default A/c
I added factory A/C to my non A/C coupe many years ago. I think I got most of the parts from a collection of early 70 cars. Are you adding A/C to a non A/C car? If so, you must cut the firewall to fit the "suitcase". Unless you are planning to remove the right side fender, you cannot install the outside air or fresh air component. Since I live in Florida, I use only recirculated inside air for cooling. I also went with a Sanden compressor as opposed to the factory A-6 compressor. That said, I would get my hands on an AIM and plan to spend about 20 hours of time doing the install. Good luck with your project. Jerry
Old Jan 14, 2016 | 11:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Buickbob
...Are there any good installation instructions around for installing it...
The 70 AIM will have a big section on the factory AC installation. Option C60. There will also be a page showing where the firewall needs additional holes drilled and the area to cut out for the heat/defrost core.
Old Jan 14, 2016 | 01:48 PM
Buickbob's Avatar
Buickbob
Thanks for all the information. I really appreciate it.
Yes I would like to add this to a original non A/C car.
Old Jan 14, 2016 | 08:22 PM
GUSTO14's Avatar
GUSTO14
I believe that you're going to find the biggest problem to be the controls. The '77 was the first year of the GM corporate radio console and the heater/A/C controls were quite different than the earlier models. You are probably going to need to purchase an early style A/C control panel to make it work.
Compressors and brackets are also different on the '77 but if you got all of the brackets (and pulleys in case they align differently) from the donor '77 and use a '77 compressor and A/C lines it should work.
Good luck... and let us know how it works out, GUSTO
Old Jan 15, 2016 | 11:24 AM
7T1vette's Avatar
7T1vette
Unless you have seriously researched and studied the vast number of differences between A/C and non-A/C Corvettes (C3's), you are treading in very murky waters. To put A/C in a non-A/C car is a very difficult and complex task. Just coming up with ALL the differences...not just the A/C components, but the wiring harnesses, etc....is a costly and time consuming process.
If you want A/C in a non-A/C car, just install one of the COMPLETE aftermarket A/C kits. If you MUST have a stock looking A/C system, sell your car and buy an A/C car; the car swap would be considerably less trouble than the A/C swap.
Old Jan 21, 2016 | 12:46 AM
ezobens's Avatar
ezobens
If you can get all the parts from a donor car, have the time and decent mechanical skills, this isn't any more difficult than swapping from an auto to a manual trans. Some folks shy away, others have no issue.
While the aftermarket units are popular, work well and are reasonably priced, I decided to go OEM as I prefer the factory look and functionality.
Probably the biggest challenge for most people is the fiberglass work-
You need to cut the hole in the firewall bigger to accommodate the A/C evaporator housing and you need to remove the air vent tube in the RH cowl and glass it over in order to install the air door in the RH cowl area (some even bypass this step).
It's all doable if you have the skill, correct parts, patience, time and documentation. AIM is a must as well as the factory shop manual.
Your biggest issue as already mentioned is the controls. The 77' control head won't work in a pre-77' C3. The vacuum harness and wiring is different as well. I'm not even sure if the air box under the dash for 77' on up is different than pre-77' but the evaporator box in the engine compartment is usable for any year C3.
Old Jan 21, 2016 | 01:14 AM
wombvette's Avatar
wombvette
And not much of the duct work is any where close to the same.
To A/C Question
