Piston ring break in thoughts and time
Was talking to my engine builder when i picked up my 5.4 triton engine after rebuild....
He claims the synthetic oils are "to good" and do not let the rings seat properly, and thus the engine will burn oil...
He says to run Dyno oil for the first 3000 miles even though the engine is a full roller engine... as the rings will not spin, and will not set with the synthetic...
now we all (most of us) know that with a flat tappet cam you MUST run a high zinc content or you will burn a lobe or 2... not fun... been there done that...
So.. this question is just for the rings...
thoughts and opinions
I use "Quickseat" during engine assembly to help the rings seat better/quicker. This is applied directly to the cylinder walls using a tiny amount of WD-40 on the walls and then work a very small amount of the powder into the walls.
It leaves a green hue on the walls.
Before the first start I fill with break in oil, which is a high zinc formula to protect the cam/valvtrain on initial startup, but contains no friction modifiers so the rings can seat properly.
This is what I use:
http://www.amsoil.com/shop/by-produc...-EA?zo=1934716
After it has been running a little to come up to temp and verify no leaks, I take the car for a cruise. Using a lower gear I do several pulls from 2500-4500 rpm (using about 3/4 throttle, not full) and let the engine slow the car back down. After the pulls I drive it home and change to a full synthetic with a new filter and treat it as normal. I have never had issues with smoking or oil consumption.
Rings seat much faster under a load due to the pressure of the gasses pushing the ring against the cylinder wall.....
Most engine builders will dyno an engine about four to seven pulls for that very reason.....so the rings are sealed.....this is supported by the increase of power on each successive pull.....
Hard 1/4 mile passes will help you......or run it hard on the E-way....
Stick cars have it easier as you can load them easier in a higher gear...
I have never used the Total seal stuff above....but know guys that do....
When the shop I worked for built Pro Stock Truck engines in 98'....they would take a freshly honed Rocket block and let it sit overnight in the shop in a specific humidity.....the resulting super thin coat of rust was what they used to help break the rings in quicker..sounds crazy...but it worked! This is what the Total Seal product is doing.
Jebby
The rings you may be most concerned with though is the oil rings. Their job is to hold back the oil. The second ring also scrapes oil off the wall, to a lesser extent.
The ring most talked about is the compression ring. This is the one that the cylinder surface is honed to and the one that is usually faced with some material other than the base iron. Although the second ring may be faced as well.
This ring will break in very quickly if moly faced.
However the second ring may be, and the oil ring is of different materials.
These rings play a big part in oil control. In our world of rebuilds and aftermarket rings we cannot duplicate the cylinder prep of an OEM engine. That to me means that we cannot use OEM break in procedures and expect the same outcome.
I have not tried to break an engine in with synthetic. OEM does it all the time but as I said have different controls in place.
Like most here I have always used regular oil, not any break in oil, just dino oil that does not have friction modifiers in it. So no energy conservation label on the bottle.
After any kind of cam break in I take the car out once it's up to full operating temp.
Then run it hard for 20 miles or so. Full throttle accel and let it decel in gear. Do this over and over.
Lots of ring pressure to insure it is mating to the cylinder wall. RPM to at least 4500.
After that change the oil. Run another 500 miles change the oil, run 1500 or so miles then over to synthetic.
I had a buddy that took his bike and followed the OEM break in procedure after a top end with piston and rings. OEM break in was a stepped process of gradually increasing use of power over about 2 to 3 hours, with cool downs.
His bike never made it's rated power after that.
He later decided to tear it down and do it again. On tear down the piston was stained almost black from the blowby of the rings.
He re-did the top and broke it in per my instruction. Then it not only made previous power levels but made a bit more power than stock.
I broke a little Suzuki car in via the method I just described. The car previous to this had never gotten better than 40 MPG. After my re-ring and break in, no other changes at all, it got 44 MPG. Good ring seal.
For an engine that has the intake manifold and heads installed the Bon Ami and oil mixture can be fed into the cylinders by inserting a small hose down each runner and then gravity will put it into the cylinders or it can be fed in thru the spark plug holes. Do NOT use Comet cleanser as it contains chlorine.
Again, back to the engine builder... He stated that some cas that first run synthetic oil will NEVER break in... Truth? Thoughts?
So.. I did run synthetic from the get go... Can the rings be seated still??
Also, as noted above REELAV8R said that driving on the freeway was a good break in but ideling it is not ........the truck moves down the freeway at 70 miles an hour at around 1500 RPM that's not much off ideal ....
My though on that is that a moly faced compression ring with appropriate surface hone will break in regardless of the oil used.
The other two rings maybe not.
Once the surface roughness that is applied to the cylinder is rounded off then there is no longer anything to mate the ring to the cylinder.
The surface roughness is little peaks and valleys. Once the rings have rounded off the peaks then there is insufficient surface roughness to wear the ring to the cylinder.
So if the rings are not broken in properly initially there is not much of a chance of them mating to the cylinder surface at a later time due to lack of remaining surface roughness.
It may be possible if the oil is what is preventing the wear in of the rings and changing to a dino oil may be the solution as Jebby mentioned.
I would go with a straight 30 wt run it hard then change it and do it again. Take compression readings before and after. You'll know if you did any good as there may a rise in PSI. You'll also know over time if oil consumption is reduced.
What do have to lose now? Run it hard in low gears for an afternoon w/dino oil in it.Sorry read of your troubles but posting here helps the rest of us. Thank you.
When first starting your engine to ensure proper ring seating, do not allow the engine to idle for long periods at a time. It is a
good idea to mildly load the engine as soon as you can. Highway driving is a good way to properly seat the rings quickly. Do
not idle the engine as idling does not break in any engine. Total Seal
® DOES NOT recommend the use of synthetic oils during
break-in. After 2000-3000 miles on the street, or one night racing on the track, the rings should be adequately seated so that
any oil you prefer can then be used.
http://www.totalseal.com/pdf/totalsealCatalog.pdf
100% EXACTLY what I ve been saying on another thread here, but the resident "experts" think Synthetic should be in it on start up and you re good to go after 20 minutes.. Rings will not seat without the friction on break-in.. It takes time ....or you can just add a quart of $8 Oil with every tank of gas if you don t believe it
I have a Ford motor home with a triton V-10 that has always used a little bit of oil since new. I was running Castrol syntec, then I tried Mobil-1. Same result.
Running from where I live, to so.Cal. is about a 3,000 mile round trip and I am pulling a 10,000 pound trailer. It would burn about 1.5 to 2 quarts on this trip every time. I started running the Schaeffer's 5-30 synthetic 9000, and I over filled it by about a pint before I started expecting it to use some oil. When I got back home I pulled the stick, and was very surprised that it was still a little over filled!
What oil are you running BTW?
Have the engine builder explain what in the synthetic oil will prevent the rings from seating,
synthetics have a more uniform molecular structure along with fewer additives, the ability to handle temp swings to the extreme better than dino's and less volatility.
what about this will cause rings not to seat?
the only true way to find the problem is to take it apart and inspect it.
a leak down will tell you to some extent what condition the compression ring is in but will not tell you anything about the oil control ring
Neal
Neal
how he explains it is that it is to good... it does not let the rings ware correctly and prevents them from the spin in there groove.
Like flat tappet lifters spin in there hole
