Why a spreader bar?
Old Jan 24, 2016 | 08:43 PM
hotrodnick's Avatar
hotrodnick
Put Speed Direct in my 79, still need to put the A/C compressor back in to finish up. I had my buddy help me. The install did take some patience. We had to pull the compressor off, as we loosened things up we found the alignment shims started to fall out. We lifted the front end which put pressure on the shims. That allowed us to install the brackets and tighten them. We let it back down on the ramps, installed the brace. I just finish tightening things up. The one thing I'm not sure of is the tightness when I turned the bars out, I think I did get almost a half turn and I heard the car creak a bit.
It is tricky to get the hands in to install, can't wait till the roads get the salt washed off to see what difference it makes. Hope this makes sense.
Old Jan 24, 2016 | 08:56 PM
diehrd's Avatar
diehrd
I must own a special c-3 . It spent months and months on 2 post lift 5 feet off the ground. At least 20 corvette guys I know ALL when seeing it on the lift like that said "good luck opening those doors ha ha" Funny my door gaps are as always perfect.
And the spreader bars are for cornering , where the frame will flex but not downward , the flex is more a twist or a movement inwards toward the opposite side . That bar just minimizes that action making the car handle better keeping the tire planted in a hard turn. IT DOES not offer frame support from sagging as the kind described by several members in this topic.
I hate to be contrary but if your coup sags or needs doors opened before it is lifted you have issues Not Built into the car from GM. But a myth spread by may owners of a C-3 who had issues they where unaware of which can range from body mounts to the bird cage being rotted .
Old Jan 25, 2016 | 09:28 AM
jb78L-82's Avatar
jb78L-82
I agree....The spreader bar does not prevent frame sag. All C3 frames will sag to some extend when put on a lift with the wheels hanging which is not permanent and will not effect the stance once back on the ground. Jacking or lifting my car does NOT prevent the doors/hood from opening/closing but I can detect a difference in the operation of such when the car is jacked/lifted. The reason there are very specific recommendations for C3 additional bracing is that the frame flexes more than what is considered ideal for this type of sports car...The C4/5/6/7 Vettes have MUCH stiffer frames than the C3 since GM knew that this area was a weakness of the C3.
Old Jan 25, 2016 | 09:44 AM
diehrd's Avatar
diehrd
Someone show me on this pic where there frame is allowing the front end to sag when you are on a lift , causing your doors to not open properly . . . . . Please just point it out
Old Jan 25, 2016 | 10:28 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I bought my '71 coupe back in September last year. The previous owner let it sit on jackstands for 31 years. When I put it on the ground I was expecting to see the door gaps change a lot, but they stayed straight. When I jack it up or have it on the ground I do not see any sag or change in gaps. I can open both doors and take the tops out with it on jackstands too. The frame has some light surface rust in areas, but otherwise still very solid.
Old Jan 25, 2016 | 10:43 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Lift arms or Jackstands set at the front position 2 feet behind the front wheels. You have nothing supporting the weight of the rest of the frame, wheels, calipers, steering components and lastly the considerable weight of the engine and transmission.
If I have mine on 4 jacks I use a scissor jack under the front crossmember to support this weight on front.
Old Jan 25, 2016 | 11:49 AM
jb78L-82's Avatar
jb78L-82
For those that think there no chassis flex issues with a C3 frame, read this:\
http://www.c3vr.com/vrforums/c3-body...s-flex/141596/
And this link which details all the weak areas of the C3 frame:
http://www.duntovmotors.com/Corvette...wer%20Book.pdf
Old Jan 25, 2016 | 11:53 AM
slickfx3's Avatar
slickfx3
i jack up the car and the doors fit different,jarder to open an close, bc of binding... i accept that
my 89 c4 did that too..
Old Jan 25, 2016 | 12:14 PM
Kubs's Avatar
Kubs
I know there is some felx, but not as bad as some people are saying. Especially when peopl say it sat on a lift or jackstands over the weekend and got all out of shape. Mine sat for 31 years and isnt that bad. I have seen big block cars that completely lose the door gap at the front bottom when jacked, but for the most part small block coupes should not be that bad.
C3 frame is a noodle torsionally, but that doesnt have to do with the flex when lifting. Lots of good info in that book though.
Old Jan 25, 2016 | 12:19 PM
jb78L-82's Avatar
jb78L-82
Yes but by today's chassis stiffness standard for just about any new car, it is a ton...
Old Jan 25, 2016 | 05:03 PM
diehrd's Avatar
diehrd
[QUOTE=jb78L-82;1591398040]For those that think there no chassis flex issues with a C3 frame, read this:\
EVERY ONE READ that link to the c3vr forum LMAO
Every one in that topic has a C-3 with issues .. Big issues ..
Hey Joe .. Ya
I lifted Vittos car
(Joe) YA SO
Well the dome light came on and the doors don't open now
(Joe) ya no big deal its a C-3 corvette
If that is how you see it more power to you..
But If my C-3 did that I would get it checked and fixed ASAP ..
Old Jan 25, 2016 | 06:08 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I welded extra stiffeners along the frame rails years ago. I just place the jack just forward of the transmission x-member and lift her up. No flex, no door gap issues, nothing.
Later I welded in a 4 point roll bar in the back. Both mods did wonders for stiffening the chassis and reducing squeeks & rattles.
Old Jan 25, 2016 | 06:15 PM
  #33
bashcraft's Avatar
bashcraft
Originally Posted by croaker
So the frames actually bent?
I would find that extremely hard to believe.
Old Jan 25, 2016 | 07:02 PM
  #34
DUB's Avatar
DUB
YES!!! Convertibles can do this. If you have any doubt....any people out there with a 1963 to 1975 raise up your car by the differential...put jack stand under the frame right in front of the rear tire. Begin letting the floor jack down a WATCH your door gap OPEN up. Depending on how 'bad' the frames steel integrity...you might find that you just about have a heart attack and begin jacking up the car again. Also consider many of these cars coming to me have a darn near fuel tank...equate that weight into the equation.
I have seen them sag so much that a GOOD cigar would fall out at the top of the door to the quarter if ti was slid in there.
ALSO...the same can occur at the front end also. If the front clip is raised under the cradle and jack stands are placed at your door peeing...ALL THAT WEIGHT of you front clip can pull down on the cowl...and problems can occur. I have seen the top section of top hood surround break away on 1968-1982's.
Originally Posted by Rcdizy
So winter storage on a 2 post hoist is a bad idea for a coupe?
I have the tall safety stands that I put under the car so I can lift up and support the engine cradle and also the differential.
Hard to say YES..because I do not know where you have the frame being picked up and supported.
DUB
Old Jan 25, 2016 | 07:15 PM
  #35
DUB's Avatar
DUB
People can believe what they want to believe and if they read what I wrote....I was referring to CONVERTIBLES...and the rear sag.
Coupes really do not sap in the rear UNLESS there is MAJOR issues in the frame and the NUMBER 3 body mount areas due to bad rust.
SO...in PERFECT WORLD where NOTHING wears out, fatigues, rusts, etc....then this would not even be a subject of conversation because we would be just ( fill in your own thoughts).
AS for showing in the photo that was posted by diehard. Stop and think about where the jack stand is positioned IN FRONT of the rear wheel on the frame....and all the weight AFTER it. Logic would tell you where the problem is occurring. And how to reverse the forces that caused the problem....a downward pull is required with supports to put it back where it needs to be....or jacking it up while the frame is anchored in the problem area.
DUB
Old Jan 25, 2016 | 07:21 PM
  #36
AboveTheLogic's Avatar
AboveTheLogic
Chassis flex is a thing. If you do enough searching around on the web you should be able to find photos of pick up trucks with their beds and cabs not aligned while the truck is flexing over a rock or something. Chassis flex is part of what makes a 4x4 truck capable of keeping the tires planted. Of course, suspension flex is much more important, but where suspension flex is lacking, chassis flex can help.
I'm inclined to believe that if the frames in those big trucks can flex, so can the frame on my C3.
It just so happens that the drivers side door of my C3 is stuck shut, too. So there's that.
Old Jan 25, 2016 | 11:02 PM
  #37
Dirty Dalton's Avatar
Dirty Dalton
I have never owned a c-3 that sagged or had door opening issues on a lift. Matter of fact my build had my c-3 on a lift for 4 months . If you have those issues you have body mount issues and or frame rot or accident damage ..
Not known as a 'Flexible Flyer' for nothing. It's very apparent with my '70 roadster when jacking.
To Why a spreader bar?
Old Jan 25, 2016 | 11:46 PM
  #38
diehrd's Avatar
diehrd
Maybe I lift my car differently ? Here is how my car was lifted this photo was after 4 plus months on a lift , from December until April .. The lift arm was always placed below the fender vent at approx the front of the S bend in the frame.
Old Jan 26, 2016 | 01:08 AM
  #39
slickfx3's Avatar
slickfx3
i thought frame flexing was engineered to be part of the suspension system
Old Jan 26, 2016 | 06:27 AM
  #40
Jason Staley
It was. Here's a couple of excerpts from an SAE paper from 1963 on the 1963 Stingray (SAE 611B if anyone wants to read the entire paper). Even though the frame is soft by today's standard, it was a huge improvement at the time, and the production configuration was even selected over a stiffer version for ride comfort. You have to remember that the tires and shocks back then were not close to the same as we have today. The frame flexibility was a conscientious decision by GM designers.
"In this new frame [1963], torsional rigidity has been increased nearly 50 percent over the previous model [1962] as shown"
"In the course of the frame development, the point arose that if stiff was good, stiffer was better. Consequently, a frame was built with torsional stiffness considerably greater than the production design. Evaluation of a vehicle equipped with the stiffer frame proved the ride to be unacceptable. This approach was quickly abandoned."
