Vacuum headlight question
Old Jan 23, 2016 | 01:02 PM
71LS5's Avatar
71LS5
St. Jude Contributor
Default Vacuum headlight question
Hi, I was wondering if anyone can tell me if a leak on the headlight actuator is an issue. I had replaced my original ones with new ones but found that both leak and do not hold vacuum.
the main question I have is do all new vacuum actuators leak or did I just get a bum pair? I figure someone has alleady gone through this.
Background info:
The new actuators loose their vacuum from 20 PSI in about 10 to 15 seconds. I looked at my old original one and it held vacuum! the other original one did not. I am having issues with my vacuum system with the new ones installed. Every thing other than the reservoir including all the lines, relays have been replaced. The tank has a very slow leak as well. Wondering if these three components have a small leak that its just too much for the main vacuum to over come.
I also found one of the new relays was not working also as it was directing air through both ports with and without a vacuum signal from the top.
Thanks in advance for your inputs!
Old Jan 23, 2016 | 01:09 PM
Iceaxe's Avatar
Iceaxe
Actuators should not leak and should hold vacuum. The entire system should hold vacuum when working correctly. A word of advice, test all new parts before you install them. I just replaced my entire vacuum system and was surprised how many new parts arrived that were faulty.
Old Jan 23, 2016 | 02:40 PM
Alan 71's Avatar
Alan 71
Hi 71,
I agree with Ice that the reproduction components available for the headlight and wiper systems are sometimes faulty.
Are you testing the components individually and in a way that will eliminate the possibility that the leak is in a hose connection, and will also let you know for certain which component is the problem?
Regards,
Alan
Old Jan 23, 2016 | 03:00 PM
V4motorsports's Avatar
V4motorsports
Try buying the repair kits. Could be as simple as one or more seals are leaking.
Hope this helps
Russ
Old Jan 23, 2016 | 03:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hope this helps
Russ
They should not leak...
So.. here is what I always tell my guys in the shop...
Always test the actuator from the backside first...
If an actuator leaks vacuum on the backside then you can toss out any idea of fixing it. This indicates that the diaphragm is leaking and the actuator can not be repaired.
If the actuator holds vacuum on the backside then you should take a hard look at the rod seal. Seals and boots are way cheaper than buying the entire actuator and if you hold vacuum on the backside you can usually repair a leaking front seal.
-Willcox
Old Jan 23, 2016 | 05:55 PM
hgpreston's Avatar
hgpreston
Replacing the front shaft seal has always worked for me. Have fixed many & still have never purchased an actuator. With that being said I have no experience with repro actuators.
Old Jan 23, 2016 | 06:41 PM
spikebot 81's Avatar
spikebot 81
I've had 2 repos fail in 7 years. Both with ruptured diaphragms. My luck with repop crap has been consistent.
Old Jan 23, 2016 | 06:57 PM
Dave J's Avatar
Dave J
My prediction; Used but vacuum tight headlight actuators will become a scarce commodity, and will be actively pursued in the aftermarkets.
Original vacuum relays can be rebuilt to function better than new, I do it all the time
Old Jan 23, 2016 | 09:24 PM
71LS5's Avatar
71LS5
Thanks all for your inputs guys. Yes I have tested the actuators and relays by themselves. I unfortunately did not test the parts when I received them (as I assumed they would not leak as new). Then they sat for almost a year until I just installed them. Both headlight actuators leak on both sides. So the diaphragms must be leaky and I see no way to fix them. Is there a way to fix a bad diaphragm? Also 1 out of the three relays was not working. This is 3/4 bad components from the same outfit.
I wonder if there is one mfg source that everyone uses as they seem to look the same and have no markings to determine date lot or manufacture.
Old Jan 24, 2016 | 05:37 PM
SwampeastMike's Avatar
SwampeastMike
No, there is no way to repair a leaking main diaphragm. I received three defective passenger side actuators before finding an original replacement. For whatever reason the first driver side actuator I received is fine.
Old Jan 24, 2016 | 05:42 PM
0Willcox Corvette
Former Vendor
The work to fix one would way exceed the cost of another one. We test ours before we send them out but even then we still have a few leak's. It's the best we can do... and it still happens.
Willcox
Old Jan 25, 2016 | 05:50 PM
71LS5's Avatar
71LS5
Thanks all for your inputs. I am going to purchase another set this time from our friends at Wilcox
Cheers
To Vacuum headlight question
