CXarb
Old Jan 26, 2016 | 07:21 PM
cdj46's Avatar
cdj46
Default CXarb
When I took off the carb on my 427 (1968) there was a thin metal plate between carb and manifold. Can anyone tell me what it is for?
Old Jan 26, 2016 | 07:32 PM
flyeri's Avatar
flyeri
Heat shield? Got a picture?
Old Jan 26, 2016 | 07:48 PM
Silvertone's Avatar
Silvertone
Waiting to see this, I'll put my money on square bore adapter.
Old Jan 26, 2016 | 07:50 PM
ddawson's Avatar
ddawson
Does it look like this under the carb. That's a heat spacer.
Old Jan 26, 2016 | 09:50 PM
Mooser's Avatar
Mooser
Assuming a qjet, doesn't the 68 BB have the hot slot on the intake? There was the thin metal shim to help transfer the pre-heat to the front of the carb (Felpro 60731)
Lars added another gasket to the 2 stock ones to provide a better seal between the shim and the qjet to seal better
Felpro 60043 (bottom), Felpro 60731 shim, Mr.Gasket 4256G (top)
M
Old Jan 26, 2016 | 10:28 PM
Kid Vette's Avatar
Kid Vette
M
Q-Jet Carb Base Gasket Tech Info: The "Hot Slot" Manifold Problem
Old Jan 26, 2016 | 10:55 PM
CanadaGrant's Avatar
CanadaGrant
Another popular way to solve this carb heat problem is to thread the two exhaust holes in the "smile" on the intake and install a couple of pipe plugs but a gasket on BOTH sides of the heat shield is the best way to prevent vacuum leaks. If you forget the metal shield you will know it pretty quickly as the engine will barely run due to exhaust gasses being sucked in through the base of the carb.
Old Jan 27, 2016 | 09:50 AM
cdj46's Avatar
cdj46
Default Carb
Thanks to all this was an eye opener for me. I do not know what I would do without the Forum. I have been working on Corvettes for ~40 years and am still learning.
Thanks Chuck
Old Jan 27, 2016 | 11:26 AM
CanadaGrant
Another problem is if you try and use a later carb on your original "smiley" manifold. The base plates are slightly different and you will get a big vacuum leak between the front of the carb and the front edge of the "smile" on the intake. The later carb base plate does not completely cover the intake heat passage.
Old Jan 27, 2016 | 03:29 PM
ddawson's Avatar
ddawson
I did the plugs when I had the Qjet and it made a huge difference keeping the carburetor cool. Before you couldn't touch it after a drive but after you could.
Old Jan 27, 2016 | 03:33 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I had 2 small freeze plugs installed in mine. I still use the 3 gasket sandwich, though.
Smiley face...
To CXarb
