Leaf Spring Replacement
I torqued the spring's retainer plate (4 bolts-70 ft/lbs.) with weight-on-wheels, and installed the spring's left end bolt nut to the shallowest depth on it's shaft that the cotter pin could be installed, with the right side to go.
Now I haven't installed the tub/spare tire yet, but other than riding around with a few bags of rock salt on the rear storage deck, is there any other way to lower the car's height a little more with this new spring? Thanks in advance.
Steve
That APPEARS to be a replacement spring of some type. (It's a little difficult to tell from this distance.)
Do you know what it's 'specs' are? All springs are not created equal.
The 2 shipping bands are still on the spring; they can come off which may help a bit.
W's longer bolts suggestion will certainly help cure the 'symptoms', but not the cause.
Regards,
Alan
Regards,
Alan
Shipping Bands Alan? Wow, I assumed those bands on the far outter ends were a permanent part which held the longer leafs in alignment. Ha.
How are they normally removed?
Steve
First Alan71 sees everything, I'm surprise how many guys here see stuff right off the bat on a photo,
Second, was just curious why you went back to the steel spring when the ride and handling of a composite spring is far superior?
I'm somewhat of a traditionalist, so that's one reason I switched.
Second, a friend GAVE me a 4-bolt main long block, which she knew I was looking for to construct a 383, which I'm currently running.
She is rebuilding a '71 right now, and I wanted to pay her back someway for that engine. At least in a small way, I'd like to think I'm attempting to do that.
That's about it.
Steve
I REALLY don't know if removing the bands will help. They are a clue that the spring is a service replacement or a reproduction.
To be truthful I don't know they come off.
I've never really looked at the bands.
Is it a metal strap like shippers use on heavy crates that needs to be cut ? Is it supposed to be slipped off the end before the spring is installed?
Regards,
Alan
Regards,
Alan
To me, it looks permanent. I was going to ask if a Dremmel cutting wheel could do it, or should I break out the big air wheel? To me, it looks like it stays there. It's no packing box band material. It's a thick gauge steel, with clean well-formed angled edges.
But this spring deal IS my 1st rodeo.
Steve
Steve
