clutch problems
Old Feb 3, 2016 | 05:18 AM
69small block's Avatar
69small block
Default clutch problems
won't release installed new clutch stage 2, suppose to have stronger clamping or holding power but will not release tried longer release bearing was way to long. any ideas 1969 350 4speed
checked disc installed ok
checked new pressure plate and old for any difference in for size height distance comparison from bellhousing to diaphragm
old was 2.3 from front face of bellhousing
new was 2.5 so it to me would be closer
any ideas
also new flywheel
also as many comparison measurements as I could all seem to be very much the same
Its a phoenix friction stage 2 set up
Old Feb 3, 2016 | 05:59 AM
toobroketoretire's Avatar
toobroketoretire
How much pedal free play do you have? Should be about one inch.
Old Feb 3, 2016 | 06:32 AM
69small block
at pedal or release bearing
Old Feb 3, 2016 | 01:19 PM
lars's Avatar
lars
Make sure you check out my article here about clutches that won't release:
https://www.corvetteforum.com/forums...and-specs.html
Lars
Old Feb 4, 2016 | 10:14 PM
croaker's Avatar
croaker
Wow wish I had read this before I did my clutch last year. Guess what clutch I used? Based on a earlier swap using that brand back in the 80's
To clutch problems
