Who has these installed?
Old Feb 4, 2016 | 05:29 PM
kansas123's Avatar
kansas123
Default Who has these installed?
Door Sound and Vapor Barriers? Did you notice much difference in the before/after? Thanks, I do not have them installed on my 72 but have been thinking about doing that.
Old Feb 4, 2016 | 06:27 PM
Gene Proko's Avatar
Gene Proko
I put them both in my 74 worth every bit of it. road noise decresed significantly
Old Feb 4, 2016 | 06:29 PM
Duane4238's Avatar
Duane4238
My vapor barriers are still on my '72. I removed a door panel to repair a door lock rod and put the barrier back on. I figured since they installed it at the factory, there must be a good reason for it. Seeing as the door panels have some fiberboard in them, the barrier is a good idea.
Duane
Old Feb 4, 2016 | 07:21 PM
DUB's Avatar
DUB
PROPERLY installed plastic vapor barriers are a MUST...
AS for adding another layer to stop sound...it surely can not hurt. I do the sound deadening on the doors when I do the interior.
DUB
Old Feb 4, 2016 | 08:47 PM
fishslayer143's Avatar
fishslayer143
most of the sound comes thru floor, but it sure can't hurt to do the doors too
Old Feb 4, 2016 | 09:16 PM
hugie82's Avatar
hugie82
Sound control is minimal but the draft in the winter is very noticeable on cold days. I drive my 82 CFI 9 months out of the year and I had mine out to fix the power door lock pigtail. That cool draft on your leg and shoulder is noticeable big time at highway speeds.
To Who has these installed?
