Fluid Leak
Old Feb 6, 2016 | 09:21 AM
rmgny44's Avatar
rmgny44
Default Fluid Leak
Could this be power steering fluid?
Old Feb 6, 2016 | 09:37 AM
G-Sting's Avatar
G-Sting
Difficult to tell from the photo, but looks greenish - like coolant. See if it has a 'sweet' smell and feels like water, not thin oil like.
If it's coolant, check around your radiator hose connections, around the thermostat housing (possible gasket failure), and around the hoses to/from the heater core.
Old Feb 6, 2016 | 09:47 AM
rmgny44's Avatar
rmgny44
It's thin and oily. No odor that I can detect.
Old Feb 6, 2016 | 10:00 AM
'75's Avatar
'75
If there's no drip hanging from the steering valve in the pic, then take a look at the brake lines above it, could be brake fluid.
Old Feb 6, 2016 | 10:15 AM
rmgny44's Avatar
rmgny44
I felt around and it does seem to be coming from the end of the steering valve.
Old Feb 6, 2016 | 11:11 AM
hugie82's Avatar
hugie82
The proportion valve is located on the frame rail right above that puddle.
Old Feb 6, 2016 | 12:22 PM
mickey5's Avatar
mickey5
Take a clean screwdriver and dip it into the PS reservoir. match the oil to the drip on the floor. Good luck.
Old Feb 6, 2016 | 01:51 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Jack it up (support with jack stands!) and get under there with a light. Then you'll know where it's coming from.
Old Feb 6, 2016 | 06:41 PM
7T1vette's Avatar
7T1vette
Different engine fluids SHOULD be different colors, different viscosities, and have different smells/tastes. Get some on your finger and smell it...taste it, if necessary. (Note: Wash hands first!)
Then, get a bit of the 'known' stuff out of a fluid reservoir and compare it. Should be easy to determine what it is.
P.S. Observing what component is just above that leak is NOT a good method for determining where it came from.
Old Feb 24, 2016 | 10:42 PM
rmgny44's Avatar
rmgny44
Leak seems to be coming from the cap at the end of the steering valve.
Old Feb 25, 2016 | 02:42 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Seems to be is not a guarantee. Wipe all the fluid off the end cap and the rest of the control valve and take a quick scoot. Check for signs of fluid. I just rebuilt my valve yesterday, lol. Mine was leaking a fair bit and it was coming from the cap. The rubber seals inside had hardened with age and weren't sealing anymore. It's not leaking now!
Old Feb 25, 2016 | 02:51 PM
rmgny44's Avatar
rmgny44
Thanks Resdoggie! I'll check this weekend!
Old Feb 25, 2016 | 02:58 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
If it is your valve and you are handy with tools, it's an easy job to rebuild.
To Fluid Leak
