quick wheel question
Old Feb 7, 2016 | 08:02 AM
sgt kohler's Avatar
sgt kohler
Default quick wheel question
im looking at some new mags for my 72. 15x8 rear 15x7 front. the rear has a 4.5 backspace. will I have to run a spacer in there to clear the e-brake and trailing arm?
Old Feb 7, 2016 | 08:17 AM
3JsVette's Avatar
3JsVette
The factory wheels are 15X8 with 4" backspace. You could run into interference with the parking brake cable. Why would you want go with a narrower wheel in the front?
Old Feb 7, 2016 | 08:22 AM
sgt kohler's Avatar
sgt kohler
should I do 8 in the front?
Old Feb 7, 2016 | 09:02 AM
3JsVette's Avatar
3JsVette
Yes
Try to find a set of wheels you like and fit your budget that are 8" wide with 4" backspace so you have no issues.
Old Feb 7, 2016 | 09:03 AM
Mooser's Avatar
Mooser
Your car you run what you want.
MY thoughts are if it's a sports car, keep some meat up front. Drag/Muscle can have some skinny front but things that were supposed to go around corners....
Also, it's a big wheel well to fill...
As for interference, as stated, there isn't a lot of room on the brake bracket (why they get moved sometimes) and it depends on the tires also.
I had 245's on stock rims scrub the bracket lightly. Others have been fine.
I think spacers will likely be needed to get the tire back out
M
Old Feb 7, 2016 | 10:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...should I do 8 in the front?...
Any reason why you specified 7s?
Old Feb 8, 2016 | 07:59 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Probably need a spacer, have 8.5s on my rear and 7 in front no noticeable difference with same width tires.
To quick wheel question
