Dynomax header and starter
Old Sep 1, 2002 | 01:45 PM
CORKYVET's Avatar
CORKYVET
Default Dynomax header and starter
Thinking about ordering a set of headers. In advance, is it necessary to remove stock starter for installation? Seem's like I saw this previously. My air conditioning and brackets have been removed permantly.
Old Sep 1, 2002 | 02:57 PM
gdh's Avatar
gdh
Default Re: Dynomax header and starter (CORKYVET)
I didn't have to. Just make sure that you install them from underneath the car. I also found the hex bolts much easier to work with than the ones that came with my Hedmans.
Old Sep 1, 2002 | 07:15 PM
Disco_Mike's Avatar
Disco_Mike
with my ancient hooker headers. the right one drops right out. i have to remove the clutch are to remove the left one. actually, you might need to loosen up the header to drop the starter.
Old Sep 1, 2002 | 07:48 PM
SteveG75's Avatar
SteveG75
Default Re: Dynomax header and starter (Got79Fever)
Passenger side Dynomax will go in or come out the top with the starter installed. The driver's side has to be installed/removed from below with the clutch linkage removed.
The starter can be installed/removed with the headers attached (been there, done that, just a little more :smash: )
Old Sep 1, 2002 | 09:25 PM
Dave68's Avatar
Dave68
Here's a word of advice for you: Do not use a stock-type starter if installing headers. Eventually (more sooner than later), you'll have a bad case of heat soak/no-start. The stock-size starter solenoid ends up being extremely close to the headers, which get very hot. After I installed a McCleod high-torque mini starter, I never had another no-start problem related to heat soak. The mini starter is much easier to install and handle, due to its small size and weight.
Dave
Old Sep 1, 2002 | 10:02 PM
Disco_Mike's Avatar
Disco_Mike
Default Re: Dynomax header and starter (Dave68)
the mini starter bolts right in?
glad i have a 4speed. i park facing downhill and hafta push start occasionally.
Old Sep 2, 2002 | 02:15 AM
Dave68's Avatar
Dave68
Yes, the one I installed had two sets of bolt holes for two different sizes of flywheels. It's a breeze to install.
To Dynomax header and starter
