Holley 750 Problem
Old Feb 16, 2016 | 07:28 PM
Kim72's Avatar
Kim72
Default Holley 750 Problem
Big block has rough idle. Found gas dripping down primary, at idle, onto the throttle blades. Carb rebuilt last year and has been running great until now. I'm assuming a gasket has let go? Any ideas? Model is 4160.
Old Feb 16, 2016 | 07:36 PM
jkippin's Avatar
jkippin
have you checked the float levels?
Old Feb 16, 2016 | 07:56 PM
7t9l82's Avatar
7t9l82
but in the same vein it sounds like some trash got in the needle and seat. You may want to check that out.simple fix.
Old Feb 16, 2016 | 08:12 PM
fishslayer143's Avatar
fishslayer143
if not needle and seat ,check power valve
Old Feb 17, 2016 | 09:28 AM
gerry72's Avatar
gerry72
Even with a blown power valve, fuel will not drip from the boosters at idle. There's not enough pressure differential in the booster for that to happen. It will run down the vacuum port in the PV depression and drip without any external clues.
Unless you fiddled with the float, the level isn't likely to have changed. You have debris in the needle/seat assembly or your float is sinking.
Old Feb 18, 2016 | 09:32 PM
Kim72's Avatar
Kim72
Fixed it!! Took the primary bowl off and cleaned everything. Put it back on and it's running great again. No fuel dripping, good idle. You we're all right. I assume it was trash in the needle/seat.
Thanks to all.
Old Feb 18, 2016 | 09:36 PM
7t9l82's Avatar
7t9l82
You don't actually need to remove the float bowl to clean the needle and seat, but it doesn't hurt to clean the bowl out too.
Old Feb 18, 2016 | 10:21 PM
Kim72's Avatar
Kim72
Ya but I wanted to check the float as well.
Old Feb 19, 2016 | 01:09 AM
mikem350's Avatar
mikem350
If the problem comes back...make sure the floats are the metal ones. The nitrofil (plastic) floats can absorb fuel, and sink, especially when hot.
If your rubber fuel lines are old, they can be breaking down from new ethanol fuels.
To Holley 750 Problem
