78 Wiring Help Needed
Center gauge area
Center gauge area cont.
Under drivers dash near fuse box
Also, in what might be the weirdest thing I've seen in a while, when the turn signals (which don't work currently) are turned on, the tach (which seems to work fine otherwise) raises by about 1,000 rpm. I'm guessing this would have to be a short in the circuit board behind the dash connecting the turn indicator and the tach circuit?
Sorry in advance, I know I'll have a lot of questions. I've been working on cars for years but this is my first c3.
http://www.vetteprojects.com/bmv/mis...tte%201978.pdf
A service manual would definitely be useful. It will have location of the plugs in addition to the colors
Having said that the absolute best electrical schematic is a 11 x 17 1978 specific-schematic published for GM with an image of the Pace Car on the front page. It combines three aspects that other schematics do not offer
- Color-coded wires
- Component location
- Circuit Operation
I have a couple but I got one at Carlisle from a vendor who specialized in Corvette documents. The other I got through eBay...it's a cleaner one that the first. An image of the cover is below
I also use a color-coded wire schematic by Olson Engineering (Don Olson) that is a one-sheet laminated schematic that I use when I need to trace a circuit through several different wire harnesses...such as speaker wire connections.
Both are the tools needed, among others, for electrical troubleshooting. I also have a dash wiring harness, used from a Pace Car that I also used for tracing dash wiring issues. But you get the idea.
Hope this helps!
I Just googled the title and came up with one on Ebay for $35 plus shipping! Get it!
thanks!!!...JP
