1971 LS5 Sending Unit Locations
Old Feb 26, 2016 | 08:12 AM
Pikeslayer's Avatar
Pikeslayer
Default 1971 LS5 Sending Unit Locations
Can anyone tell me the location and style of the water temp sending unit? I have found 3 different types. Unthreaded post, threaded post, and a two blade style. Also, where does the oil pressure gauge line go and the oil pressure sending unit (if there is one).
Thanks!
Old Feb 26, 2016 | 09:19 AM
Alan 71's Avatar
Alan 71
Hi P,
For 71 the temperature sender has a 'pin' type (unthreaded) connector and is located in left side head between the 2 forward spark plugs.
For 71 bb engines the connection for the oil pressure line (no sender) is on the side/rear of the left side head.
Regards,
Alan
Old Feb 26, 2016 | 09:26 AM
Pikeslayer's Avatar
Pikeslayer
Originally Posted by Alan 71
Hi P,
For 71 the temperature sender has a 'pin' type connector and is located in left side head between the 2 forward spark plugs.
Regards,
Alan
Alan,
Do you know what the brass piece in the picture below is? It is hard to see. It is just to the right of the dip stick below the valve cover.
Old Feb 26, 2016 | 09:46 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
That is probably the CEC temp switch. It should have two prongs and be connected to a green harness. It would be for the emissions control system.
Old Feb 26, 2016 | 09:52 AM
Alan 71's Avatar
Alan 71
Hi Sig,
You posted while I was trying to figure out if that was a 70 or 71!
Hi P,
If this is in fact a 71 it's likely that that's another temperature sensor/switch that is part of the CEC emissions system that 71 cars had. Combined Emission Control.
I'm more familiar with sb engines and that's near the location for that sensor on the 350 engines.
It typically has a single 2 spade connector.
Might that be what you're seeing.
Regards,
Alan
Hi, I looked again and that's not a 71 car in the pic, it's a 70. That confused me.
Here's the switch on a sb engine… I'd think it would be the same switch on your bb.
Old Feb 26, 2016 | 10:55 AM
QuRace's Avatar
QuRace
Yes it is - but in '70/'71 it usually goes by the name TCS System (Transmission Controlled Spark).
Old Feb 26, 2016 | 11:30 AM
Pikeslayer's Avatar
Pikeslayer
So would a 1971 auto transmission LS5 have 2 senders? One for the gauge and one for TCS? And a manual only have one for the gauge?
Old Feb 26, 2016 | 12:48 PM
Sigforty's Avatar
Sigforty
All should have both regardless of transmission.
Old Feb 26, 2016 | 01:48 PM
Pikeslayer's Avatar
Pikeslayer
Thanks! Guess I'll order both. One last thing. Which style of terminal is used? See below..
Or
Old Feb 26, 2016 | 03:20 PM
Sigforty's Avatar
Sigforty
My temp sender in the driver's side uses a terminal like the first picture. Nail head.
Old Feb 26, 2016 | 03:26 PM
Alan 71's Avatar
Alan 71
Hi P,
In the picture the lower 'pin' sensor would have been typical for your 71 and the connector in the harness should be for that 'pin'.
The system we're talking about for 71 is called Combined Emission Control.
It has different hardware than the TCS systems that was used for 1970 and 1972.
For the 1971 CEC system the hardware is:
A solenoid mounted on the left front of the carburetor with an electrical and vacuum connections.
2 relays mounted on the firewall to the left of the engine. A Reversing Relay, and a Delay Timer Relay.
The temperature sensor/switch in the right side head.
A switch mounted in the transmission case that, for 71 cars w/4-speed transmissions, monitors when the transmission is in 3rd and 4th gears. On 4-speed cars the shifter shaft activates the switch while on automatic cars I believe it's the fluid pressure.
The engine harness contains the electrical wire ring and connections for all these parts. Except for a short jumper lead from the harness to the temperature sensor in the right side head.
All 71 model year cars left St.Louis with this system.
Regards,
Alan
CEC Solenoid.
Reversing Relay and Delay Timer Relay.
Sensor for 3rd & 4th in transmission in a 4-speed equipped car.
Old Feb 26, 2016 | 05:00 PM
7T1vette's Avatar
7T1vette
The 'single pin' temp gauge sender is on the LEFT side head between cyl #1 and #3. The 'two pin' TCS temp switch is on the RIGHT side head between cyl #6 and #8.
The TCS sender DOES have a wire on it that runs from one of the pins to the other. [One terminal is for 'temp too low'; the other is for 'temp too high'. And either can send the same signal to the TCS system, as they might occur.]
Old Feb 26, 2016 | 06:01 PM
Alan 71's Avatar
Alan 71
Hi P,
To clarify…
The sender in the LEFT side head is for the center gauge cluster temperature gauge only. It is a pin connector in 1971.
The sensor in the RIGHT side head that you asked about using the picture is part of the 71 ONLY CEC system which I described, the TCS system was used in 1970 and 1972. The sender served the same function for the 3 years.
I mention this again because if you look for TCS info it won't help you, you need to look for CEC information.
Regards,
Alan
GM issued a specific manual for the 71 CEC system (and maybe for other years too) that went to the dealership service departments. The manual is 27 pages.
If you're thinking about getting the CEC operating, (if it's not), on your car the manual will be a big help. They're available on the bay pretty regularly at reasonable prices.
This is the sort of info it contains and how it's presented.
Old Feb 29, 2016 | 09:25 AM
Pikeslayer's Avatar
Pikeslayer
Hi P,
Regards,
Alan
Oil fitting goes into the head? I didn't think there was oil pressure present in the cylinder heads. I thought it got there through the push rods. Would it go just above the filter? See below.
Old Feb 29, 2016 | 10:34 AM
Alan 71's Avatar
Alan 71
Hi P,
I said head by mistake, sorry!, it's in the block just below the head and above the oil filter.
If you have a 71 AIM look at UPC LS5, Sheet A5. This page shows the proper parts and their assembly for the oil line to the gauge.
If you don't have the AIM go to the Paragon Corvette Reproductions site and look at the page for the 454 oil line connection parts. There's a nice drawing showing all the parts in place.
The plugged fitting in your picture is the first piece of what's needed for the oil line. You see that elbow in the drawings.
Good Luck!
Regards,
Alan
To 1971 LS5 Sending Unit Locations
