Is it worth upgrading stock 1971 Corvette with 350cui and 270bhp with HEI distributor?
Will it give any benefits?
I'm looking at this from my beloved supplier: https://willcoxcorvette.com/corvette...i-w-tach-drive
It depends really. I have had no issue setting up points and having the car run fine. Some people think the HEI is easier and more efficient. I personally wouldn't spend the money unless the stock unit was broken or going to cost a lot to repair, especially on a stock engine where you probably won't notice much of a difference.
I would use a Ready to Run MSD or Mallory. There are a few reasons for this....but the main two reasons are the physical size of a HEI....and the fact that they are not conducive to setting up a nice advance curve unless the weights are modified.
There is nothing wrong with a HEI unit.....I just do not like them.
There is nothing wrong with points either.....unless you leave the key on and the contacts are closed
An electronic ignition tends to start easier and run crisper.....especially with a Spark Box......but points work remarkably well....and you will see zero actual power gain.
If you have a lot of miles on your stock distributor and are having problems with it I would find someone to rebuild and recurve it. The distributor you are looking at is most likely built in china.....some have marginal modules in them. I always think the hei big heads look out of place in a classic c3 like yours!!
Reason: more info
If you like tuning and understand how points distributors work then keep it. If that's not your thing switch to an HEI. But I wouldnt trust one of the cheap ones as mentioned above....
I asked the local speed shop about getting my points distributor recurved, they dont have a machine and dont know anyone that does. He says, most people do it by feel. Whatever.
HEI's are great as long as you have a quality module in them. The cheap Chinese-made modules will quit at the worst possible time so only buy quality American-made modules like AC Delco or Standard Motor Products.
Jeff at advanced distributors in shakopee, mn. ( 612-804-5543 ) can rebuild and recurve your factory unit at a reasonable price. Website is advanceddistributors.com. Jeff does great work!
The main difference is better starting and better throttle response... and I would think that low rpm torque feels a little stronger... and fuel consumption seems to be a little lower. However, very important... you will also have to upgrade with the required spark plugs and spark plug wires!
However, I would definitely recommend a distributor from a well known manufacturer and no "aftermarket crap"... because from a cheap one you will not get the benefits... and in the end might buy the expensive one afterwards anyway!
Go to your local parts store and buy a 1975 GM HEI...Its a one wire
distributor....The GM distributors are as good as they get....not fancy but you cant buy any better,
much cheaper also...
The brand we sold is A`1 Cardone.
In my opinion to keep it stock looking I would go with a Petronix drop in complete distributor. They have the small style cap similar to the '72. I was in the same position last year, buying a distributor set-up for a '69, took a TPI set-up out w/HEI & decided to keep a electronic ignition.
I just installed a after market hei with tach drive in my 72. I have the dual snorkel air cleaner on it . I installed it in about a half hr.. ran one wire from the fuse box on the ignition post. it cranked right up and I set the timing..
