&00 R4 Shifter issues
Old Mar 17, 2016 | 06:09 PM
MyklB's Avatar
MyklB
Default &00 R4 Shifter issues
I have a 77 small block I put a 700 R4 transmission in. With the stock shifter low gear sets in 1st and 2nd gear position. Is there a way the stock shifter can be used to set in 1st gear? My mechanic told me he could not adjust the shifter to accommodate a 1st gear position because the original shifter was designed for a 3 speed automatic. Thanks
Old Mar 17, 2016 | 06:29 PM
cboyd's Avatar
cboyd
I put a 2004R in my '79, but had to use a kit from, I think shift works that come with the proper detent and overdrive indicator.
http://www.shiftworks.com/corvette-68-81.htm
Old Mar 17, 2016 | 06:45 PM
toobroketoretire's Avatar
toobroketoretire
To be able to put it into 1st gear you'll need a shorter lever at the transmission. I think all of the TH700R4's have the same internal detent plate inside the transmission so all you'd need is the shorter external lever, You could have your mechanic weld the lever's 1/4" hole closed then re-drill it lower but I don't know how much lower so your mechanic would have to experiment with it.
Or, buy lever for a pickup truck that is already shorter.
Old Mar 17, 2016 | 06:54 PM
MyklB's Avatar
MyklB
Looked it up, thank you.
Old Mar 17, 2016 | 07:14 PM
bluedawg's Avatar
bluedawg
Shift works, they have a conversion kit, works great, i will suggest you get the shift works shifter cable, it's the best going.
Old Mar 17, 2016 | 07:16 PM
fishslayer143's Avatar
fishslayer143
I used a Shifter conversion kit from Shiftworks .. everything you need. about $100
Old Mar 17, 2016 | 07:47 PM
MyklB's Avatar
MyklB
Thanks, looks like i have my answer. Ordering now
Old Mar 17, 2016 | 09:02 PM
7T1vette's Avatar
7T1vette
The detent plate mounted on the side of the shifter needs to have another "notch" cut out of it. The 4-speed auto tranny (700R4) has an extra detent notch for first range. You can modify your plate or purchase one from some of the aftermarket transmission kit suppliers.
Once you see the difference between those plates, it's pretty easy to use a Dremel or similar tool to modify yours. Perhaps someone on this Forum will show a photo of each so you can DIY it.
Old Mar 18, 2016 | 02:03 PM
rmm82's Avatar
rmm82
Take a look at this thread - https://www.corvetteforum.com/forums...etent-mod.html
Works perfectly.
Old Mar 20, 2016 | 07:50 AM
Cool95vette's Avatar
Cool95vette
Works perfectly.
I did this modification on mine. Took about 30 minutes. No need for a shorter lever.
To &00 R4 Shifter issues
