Need to replace headlight bulbs
Old Mar 24, 2016 | 10:01 PM
flyguy767's Avatar
flyguy767
Default Need to replace headlight bulbs
I have a 1977 that I just converted to electric operated headlamp operation. They work great, but my right side high beam and low beam bulbs need replacement. Any guidance or tricks to replacing only the bulbs?
Old Mar 25, 2016 | 07:53 AM
Alan 71's Avatar
Alan 71
Hi 767,
The headlights should be up.
The headlight bezel need to be removed.
Then remove the 3 small screws that hold the headlight ring to the headlight cup.
Unplug the headlight.
If you don't touch the scores that aim the headlight you won't have to re-aim the new one.
Regards,
Alan
Bezel removed…. 4 screws.
3 small screws on ss ring.
Old Mar 25, 2016 | 10:58 AM
ddawson's Avatar
ddawson
I found getting the bezel out the hardest part.
Couldn't get the light up high enough to clear the bumper.
Old Mar 25, 2016 | 02:29 PM
Peterbuilt's Avatar
Peterbuilt
Sometimes you have to adjust the 'up-stop' to get the bezel out.
Old Mar 25, 2016 | 03:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes it is tight, I put a very thin cloth in between the bottom of the headlight bezel and the body to avoid scratches.
To Need to replace headlight bulbs
