Glass T-Top refinishing
Is there any way to refinish the t tops on my vette? The ones I have a obivously not a matching set. One is just a shade different then the other. The have the mirror finish and I was wondering if there is anything I can do?
If they are MIRRORED glass tops...where you can see though them...there is nothing you can do.
DUB
DUB
Don't know if this would help, but here in HOT SUNNY FL we would add window tint to our T Tops. Not on vettes, but they came dark tinted, just not dark enough.
I know you can make a mirror...but I do not think it is so you can see through it like your T-tops are.
www.youtube.com/watch?v=fJdCMiAsr6c
DUB
NO! And NOT have it last. 'minitech' must not be aware that your tops are mirrored tops...and NOT fiberglass tops that can be painted. Your thread kinda threw me because the word 'glass' can be taken two different ways which is why I had to understand what you meant. 'Glass' is often times used to describe 'fiberglass' also.
DUB
DUB
Not that it helps the color but I had my windshield and glass tops coated with a clear heat reflecting ceramic film,what a huge difference when driving.
I think it was a lumbar product,most tint shops have it but it's tough to work with so some won't do it. I did all the glass in my ford edge sport and it made a huge difference.
http://solutions.3m.com/wps/portal/3...eramic-Series/
If You look in the corner of the Glass You should see who made the Glass. The PPG ones were considered the best, and they came on the late C3's. You might keep an eye out on the for sale page on this sight as well as the local Craigs List. Sooner or later You will come up with a Match. Just a stupid question, are You sure somebody hasn't put that cheap window tint film on one of the Tops ?
I have had to change the original LOF BLUE tops due to the exterior mirror changed and the BLUE tint from the inside actually faded out and was no longer there.
DUB
DUB
