FWIW: console HP tags can be meaningless. Too easy to change. Order a reproduction L-88 tag and you'll have an "L-88" in the time it takes to swap tags.
Either the engine and console tag have been changed (most likely) and/or the tach has been changed to one for a base SB.
But, does it really matter to you if you like the car and the price is right?
Well, it's going to take a lot of work to get the car where I want it so would mean more and be easier not to loose interest if it were original. Also if not original it questions what else I will run in to. When I check the engine, if the numbers match what else can j check to see if its a real big block car?
...When I check the engine, if the numbers match what else can j check to see if its a real big block car?...
If the numbers match, as the seller why someone went to all the trouble of installing a small block base engine tachometer. The second thing to check is whether the seller has any factory documentation for the car.
Thanks!
Rear end will have caps not u bolts holding u joint to differential .What history does seller have ??
