Holley Carb Spec Question
Old Apr 30, 2016 | 04:41 PM
KJL's Avatar
KJL
Default Holley Carb Spec Question
Where can I get primary/secondary jet, air bleed and metering block emulsion air bleed size, PV set up and squirted size information for an out of the box Holley 950 HP carb with mechanical secondaries?
Old Apr 30, 2016 | 06:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Usually google the PN or model # and go from there
Old Apr 30, 2016 | 07:32 PM
GUSTO14's Avatar
GUSTO14
If you know the LST number you can probably find it here in the attached PDF (under Carb Number) along with most of the data you're requesting...
Good luck... GUSTO
File Type: pdf
Old May 1, 2016 | 01:31 PM
KJL's Avatar
KJL
Good luck... GUSTO
Thanks!!
Old May 1, 2016 | 11:09 PM
lars's Avatar
lars
You have to call the Holley tech line - they don't publish all those numbers. The published info is limited to jet sizes, PV spec, squirter sizes and some of the other more common specs.
Lars
Old May 2, 2016 | 10:52 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You can get a set of pin drills ( not expesive ) and measure them with the ends of the drills. The jets should be stamped with the number
Old May 2, 2016 | 12:16 PM
ddawson's Avatar
ddawson
I had to get one of these the read the stamping.
With the little section I can read the numbers on the fuel restrictors.
I wonder how the manage to stamp that tiny part.
To Holley Carb Spec Question
