Identification for a crate engine
Old May 7, 2016 | 11:32 PM
FJC's Avatar
FJC
Default Engine Identification
I'm looking to find out whatever I can about what I believe is a crate engine to my 69. The Eddelbrock intake manifold is painted yellow and the block has the following stamped on it:
06A104038
V0904TKB (The T may possibly be a 1, larger print than the first group of numbers.)
I believe it is a 350 crate Edelbrock engine but I really have no idea.
Old May 8, 2016 | 12:22 AM
FJC's Avatar
FJC
Nevermind... Little more research and I figured it out. It's either a 350 truck engine from a 76 or 79 Chevy. The rest I guess I'll have to find out along the way!
Old May 8, 2016 | 10:31 AM
FJC's Avatar
FJC
Anyone have a line on the first string of numbers? I've been looking around and I think it's probably part of a vin for the car/truck the engine was originally on but can't find anything else. I'd like to know where the engine came from/off of.
Old May 9, 2016 | 08:18 AM
augiedoggy's Avatar
augiedoggy
its a 4 bolt truck block like you stated...I used a block from a 76 heavy duty truck myself when building the engine for my 74 and the id # is similiar ... supposedly a High nickel block too by the 020 and another marking I cant remember elsewhere on the block which is debatable since there apparently are no records available to the public linking any specific #S to the metal content for sure...
Old Mar 11, 2024 | 07:38 PM
Madman151's Avatar
Madman151
2nd Gear
Default Chevy 350 smb need help
I recently picked up a motor year 1972 stamped block #3970014 the #s on the pad T0922CKL and 13C120690 crank #3932442 I don't have any clue what this came out of I bought for the right price i have a melling 22200 cam and lifters 7qt oil pan hi rise single plane manifold and 650cfm carb thats going to be put on it i have no idea how much HP it will make i do intend to put it on a Dyno please anyone that can give me an idea on the block would be extremely appreciated i
​​​​I think they are 75cc heads
Crank
Crank
Crank
Main
Head #
Head #
Head #
Head time mark
Head #
Front of head
Pad info
Pad info
Block #
Block time
Block #
Head mark
Pad info
Old Mar 12, 2024 | 12:40 PM
carriljc's Avatar
carriljc
FJC
according to my lime book TKB was used for the following engines in trucks
Old Mar 28, 2024 | 10:45 PM
Madman151's Avatar
Madman151
2nd Gear
The stamp is CKL
Old Mar 29, 2024 | 12:05 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by Madman151
I recently picked up a motor year 1972 stamped block #3970014 the #s on the pad T0922CKL and 13C120690 crank #3932442 I don't have any clue what this came out of...
The stamp is CKL
Probably would have been better to put your Q and pics in a new thread.
You can find the Lime Book PDF in the C2 forum stickies.
The CKL stamp fits a number of different models, but not Corvette. One of the biggest clues for it not being a Corvette engine is that the Tonawanda foundry (indicated by the T in the engine stamp and castings) did not make any small blocks for Corvette, just big blocks. Being that it has a 1972 casting date, it's likely the 350ci/145hp.
Old Mar 29, 2024 | 12:19 AM
barkingrats
Madman–
PS: The C in the VIN sequence (13C120690) indicates the Southgate, California, assembly plant used for passenger cars. (Corvettes used the S code for St. Louis.)
Old Mar 29, 2024 | 12:26 AM
lars's Avatar
lars
Your post has nothing to do with the original poster's question, which is identification of a crate engine, and he has not been active on this Forum for 8 years. If you want answers to your new topic and question, start a new topic thread.
Lars
To Identification for a crate engine
