1969 External Voltage Regulator?
Old May 10, 2016 | 10:26 AM
CrossedUp's Avatar
CrossedUp
Default 1969 External Voltage Regulator?
Please help, I'm a little confused. I took the alternator from my basket case, '69 427/435 into the local auto electric shop to have it checked out. I got a call from them about an hour later and asking if I was aware that it was externally regulated like this was something that was unexpected. I'm almost certain it's the unit that came off the car when it was last running but, I've also read on this forum that '68 was the last year for external regulators on Corvettes. The car's trim tag shows "F16" which I believe means a build date of January 16 1969.
Thanks,
-Doug
Old May 10, 2016 | 11:45 AM
mikem350's Avatar
mikem350
Having an external regulator is unexpected to THEM as they don't have one on their test set up.
Remember our cars are 40+ years old, alternators now have an internal regulator, and the guy testing parts does not even know what a carb is.
Old May 10, 2016 | 12:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There is probably an F16 in every model year. 68s were the last cars to have a voltage regulator. They mount on the left fender skirt.
Does your car have a voltage regulator on the skirt?
What is the VIN? It will show 8 for 68 and 9 for 69 as the model year codes.
Old May 10, 2016 | 12:11 PM
CrossedUp's Avatar
CrossedUp
Since a front clip was installed (before I got it) with new inner fenders and the engine wiring harness was badly damaged, I have no way of knowing.
The VIN: 194379S713367
Thanks,
-Doug
Old May 10, 2016 | 12:37 PM
Ironcross's Avatar
Ironcross
If it has a external regulator it`s a 68, internal regulated alternators first appeared as a 69 part......
Old May 10, 2016 | 12:53 PM
Barry's70LT1's Avatar
Barry's70LT1
Trivia from the past....
Shortly after I purchased my '70, new, the alternator failed. Actually it was the internal regulator. At that time there were no replacement regulators available. Apparently there was a very high failure rate of the regulators at that time.
Under warranty, the dealer installed an external regulator. After several months, I was advised by the dealer to come in and have my alternator converted back to an internal regulator.
Yours may have had the same problem years ago and never got converted back.
Old May 10, 2016 | 03:42 PM
CrossedUp's Avatar
CrossedUp
That's a definite possibility Barry. The auto electric guy said there was a place in the alternator housing for a regulator but it just wasn't there. I wish there was more of the wiring harness left intact that might confirm this theory.
Thanks,
-Doug
Old May 10, 2016 | 05:24 PM
mikem350's Avatar
mikem350
If the wiring is that messed up I would buy a new engine harness for a 70, and use the internal regulator alternator (cheap, and will look better than a 40 year old part)!
Will prevent a lot of headaches/problems! When assembling pay attention to the extra grounds Vettes need being fiberglass bodied.
Old May 12, 2016 | 06:29 AM
gungatim's Avatar
gungatim
Thanks,
-Doug
how exactly is that possible? without the regulator, how is the brush holder mounted?
how many wires were connected to the alternator when you removed it, and where were they connected?
maybe you have a 1-wire alternator with the plug capped off so it looks like there is no regulator.
Old May 12, 2016 | 10:12 AM
lionelhutz's Avatar
lionelhutz
The brush holder and regulator are 2 different pieces in a 10SI alternator so technically it would be possible. The brush holder does mount on top of the regulator so some kind of spacer would be required.
In reality, they probably just swapped on a 10DI alternator until they got the parts to fix the 10SI alternator.
Also in reality, the parts store guy probably doesn't know what he's talking about when saying there was a space for a regulator.
Old May 12, 2016 | 11:20 AM
gungatim's Avatar
gungatim
that's what I meant, if the regulator was gone it seems like an awful lot of work to make the brush holder mount properly, if someone modded it, you'd just leave the regulator in there and not hook it up so why go to the trouble...
my bet is the parts store guy is an idiot. I had a 1-wire on my ford tractor 6v to 12v conversion that went bad and the guy at the parts store was clueless how to test it or even get another one until I explained and an older worker pushed him aside to do it right
Old May 12, 2016 | 01:22 PM
CrossedUp's Avatar
CrossedUp
The alternator is a 1100882, 61 Amp with the date code 8L12 (December 12 1968?)
I took it to an auto electric specialist (not a parts house) who replaced all the internals, installed a new regulator and, IMO, definitely does know what he's talking about.
To 1969 External Voltage Regulator?
