Hi bb,
I believe that while 350 cu.in. engines use a mounting plate, 454 cu.in. engines only use a gasket between the fuel pump and the block's flange.
The proper fuel pump mounting is shown in the AIM section for the 454 option.
Regards,
Alan
Alan is correct, the parts book only shows the plate being used on small blocks. Have you tried mounting the pump with gasket directly to the block and ran into an issue?
No i haven't tried directly yet. i was just trying to see if i could find the correct way the first time, that was all.
