1968 3 Speed
Old May 29, 2016 | 11:34 AM
jmsj's Avatar
jmsj
Navigator
Default 1968 3 Speed
I recently picked up a 68 with a saginaw 3 speeed - I know.....not many around. considering changing it to a 4 speed. Is it as simple as swapping the transmission and shifter? or is there more involved.
Also interested to hear opinions as to whether I SHOULD do it. I understand it's rare. Rare is good when you're talking about an L88. This is a 327/300hp. The 3 speed is rare because people wanted 4 speeds.
thanks!
Old May 29, 2016 | 11:53 AM
rklessdriver's Avatar
rklessdriver
You need to find an early Muncie with the 10 spline input shaft and shifter and it's a direct swap.
If you use a later Muncie or BW ST10 with the 26 spline input then you will need a new/correct clutch disk and driveshaft yolk.
As for the "SHOULD"... it's your car and you can do with it what you want. Besides swapping a 3spd to a 4spd is not a big deal. It's an easily reversible modification as long as you keep the original 3spd transmission and shifter assembly under your work bench.... Look how many of us are swapping in 5 and 6 spd transmissions today to make our cars better drivers.
Will
Old May 29, 2016 | 12:03 PM
midigike's Avatar
midigike
VERY rare! I believe the made about three hundred of those before they discontinued the option. I can understand your dilemma, because I have a three speed auto and it could use another gear. I'm curious as to what rear gear ratio you have.
Like already stated throw in a 4-5-6 speed and nicely crate up the 3 speed and enjoy the ride.
Old May 29, 2016 | 12:04 PM
pawpaws toy's Avatar
pawpaws toy
If the figures I found are correct, only 353 3 speeds were built out of a total of 28566 corvettes in 1968
Old May 29, 2016 | 01:26 PM
Giddy-up Go's Avatar
Giddy-up Go
How does it run with three? Is it decent response?, are the rpms in an acceptable range?, does it get decent fuel mileage? What are you looking for performance/ driving wise? As stated, if you choose to change it out, keep it for resale as it is obviously a VERY rare option. Do what makes it fun to drive and enjoy it!
Old May 29, 2016 | 02:24 PM
jmsj's Avatar
jmsj
Navigator
I'll definitely keep everything. Not sure how it runs with the 3 speed. I got it with the engine and transmission out of the car. I've driven other 3 speeds (not vettes) and it's felt like something was missing. So, i figured if I'm going to do it, now is the time.
Old May 29, 2016 | 02:28 PM
AboveTheLogic's Avatar
AboveTheLogic
If you install a 4-speed, then you might regret (in the future) not installing an OD trans (5 or 6 speed) instead.
Old May 29, 2016 | 06:24 PM
flyeri's Avatar
flyeri
I agree with this. Having the OD is really nice if you really want to drive the car. We drive ours on all day 200-400 mile adventures. If you're just going to cruise-ins and shows and putting low miles on it then 3 or 4 spd would be fine. If you are worried about original leave the 3 spd. In any case keep it.
Old May 29, 2016 | 06:54 PM
tyrant's Avatar
tyrant
<br >
Unfortunately mine was removed just before I bought it. Still trying to hunt it down.
Old May 30, 2016 | 09:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by jmsj
..The 3 speed is rare because people wanted 4 speeds...
To be honest, the 3 speed is rare because most people wanted anything other than the 3spd.
Originally Posted by pawpaws toy
...only 353 3 speeds were built out of a total of 28566 corvettes in 1968...
I haven't done the math in a while, but that's probably in the neighborhood. For 68 and 69, the 3 speed manual was the base transmission. You got the 3 speed unless you ordered something different. All other trannies were optional at extra cost. Most people opted for a four speed or the TH400.
The wide ratio four speed became the base transmission beginning with the 1970 model year.
Old May 30, 2016 | 07:36 PM
PRNDL's Avatar
PRNDL
I was going to ask you how original the car was otherwise, and I was leaning towards leaving the 3 speed in just for the sake of the novelty and rarity - although I would never suggest rarity=value in this case....
BUT, with the trans already out of the car, as long as you are keeping it, put in whatever the heck you want! 4 spd, 5 spd, overdrive, CVT... go for it!
(I had 3 on the floor in my first car.... it was a 74 AMC Gremlin X!!! ...yep, sure felt like something was missing... an engine! )
Old May 30, 2016 | 10:10 PM
myoriginal77's Avatar
myoriginal77
I'd leave it - I've only seen one other -
Frank
Old May 31, 2016 | 02:49 PM
gungatim's Avatar
gungatim
honestly I didn't even know a 3spd was offered (except auto), but subtracting optional transmissions from total production I get 326 that must be the 3spd.
M20 4-Speed Manual Transmission 10,760
M21 4-Speed Man Trans, close ratio 12,337
M22 4-Speed Man Trans, close ratio, hd 80
M40 Turbo Hydra-Matic Automatic Trans 5,063
I know splitting hairs....
but I would ditch it, put in a 5spd. if you're going to do anything may as well do it all the way. of course keep the old parts in case a future owner wants to return it to stock, but as stated on here many times before, "Rare doesn't mean desirable!"
Old May 31, 2016 | 03:02 PM
bashcraft's Avatar
bashcraft
Frank
There's a reason for that, and it's not a good reason.
Old May 31, 2016 | 03:27 PM
keithinspace's Avatar
keithinspace
It is an odd one, isn't it?
What if they offered a 2 speed automatic? And there were only 4 individuals that purchased said 'option'?
I have 1 of 4 ever produced!!! Awesome!!! Well...ya...it actually drives like a pig. I hate it. But it sure is rare!
The only 3 speed I ever drove was a column shift. Remember those? They weren't too fast, either.
I have to say, though...that shift pattern is a great example of elegant simplicity.
I'm with others. If making ANY switch, I'd go straight to a 5 speed. Wouldn't even think about it.
Old May 31, 2016 | 04:27 PM
BarryB72's Avatar
BarryB72
It's actually a $2500 "option" now, according to the corvette DNA app. And it says 326 were made as well.
Old Jun 1, 2016 | 02:03 AM
mikem350's Avatar
mikem350
CVT...LOL, that really cracked me up
To 1968 3 Speed
Old Jun 1, 2016 | 02:16 AM
AboveTheLogic
How about an auto with a 4,000rpm stall converter? Practically a CVT
Old Jun 1, 2016 | 10:11 AM
pawpaws toy
You are right. When adding the numbers, I transposed 5063 to 5036 for the TH400. A 4-speed was a $184.35 option
Old Jun 1, 2016 | 11:45 AM
BLUE1972's Avatar
BLUE1972
I would go with a 5 speed conversion - no cutting, and put the 3 speed into a bag and box for the future.
I did the 4 sp to 5 sp conversion on my 71 and it's the best thing if you want to drive the car. A/C is another great thing - next year.
If it's a show queen / NCRS keep the 3 speed.
