regulating pressure to carb that is clearly already too low seems to be attacking the wrong problem ...His return is too large, thereby lowering his available supply pressure .a regulator set at 6psi will not help 2 psi available supply.. . reduce return flow, increase supply pressure .. then , if you want to, regulate it to carb
My fuel lines are -6 braided with AN fittings. After read an old post from Lars I installed a return line. In install an AN -6 "T" at the rear feed (Holly style dual feed). From the open connection I used an AN -6 to -4 reduced. I treaded the -4 end for 10-32 and installed a brass screw. Then cut the screw flush with the flair fittings tip. Then drilled 040 hole through the screw. Install a -4 180* hose end and ran -4 hose to the stock 5/16" return line with a 5/16 / -4 AN male fitting to the tubing. Hooked up line and works great. Not only prevents vapor lock it stops the pump from dead heading.
I believe thats the same post I've been trying to copy. Those guys did some really nice looking plumbing work.
Thanks to all who shared their ideas. And I can see all of them working out. My current FP seems to be working fine and all I need is a return. At this point I'm going to work on limiting my return line size and hopefully ending my vapor lock issues.
did you connect your return to an actual fuel pump return line or did you connect it to the line that normal would feed vapors to the charcoal canister?
I connected the -4 return line to the return line on the right frame rail that was used for the mechanical pump return. Used a 5/16 compression fitting to -4 AN male to connect the -4 AN return line. My electric pump and filter are located back at the tank. The return line goes directly back to the tank as the factory installed the hard line.
Limited my return size and moved my pump to carb fuel line to a cooler location.
For some reason after moving line my fuel pressure gained 1 psi and now idles at 8 with return line connected. When I shut her down it drops to around 3 to 4
I went for a drive to warm the engine and let her idle of 35 minutes after I got home. No vapor lock so far.
Still wanna test some more before I trust the car but I'm happy so far.
Originally Posted by Bloodzone
This is the setup I was trying to copy. Only mine is not elegant.
That setup has a .060" diameter hole drilled into the stainless reducer fitting coming out of the rear "T." The plugged and welded fitting is shown in one of the photos below the installation setup. This hole keep fuel pressure from dropping much more than about 1 psi.
Lars
If I am running my return with .040 should I open that up to .060? My system is stock hard lines with -6 AN supply and -4 AN return. Pump is 100 gpm and regulator is set holding 7 psi.
Not high jacking just another example.
I just added a restriction to my return line so I have no idea what size opening I have. Only data I have is that I run 7-8 psi at idle and it drops to 3ish when I turn off engine and them slowly drops over time.
Thats perfect... Don't mess with it. If its not vapor locking, don't worry about it.
FWIW, I never run return lines on carb'd stuff with mechanical fuel pumps... Usually no problems with vapor lock assuming I have a GOOD pump on it. Between my dad and I, we have 7 cars with carbs/mechanical pumps, and I set them all up the same way.
