remove seat belt
Old Jun 12, 2016 | 11:26 PM
biackbenz's Avatar
biackbenz
Default remove seat belt
I need to unbolt the seat belt where it anchors to the outside frame. I removed the seat for access. But I cant budge the bolt. Even bent the torx socket. Is there a secret to removing this bolt? 1978.
Old Jun 13, 2016 | 05:42 AM
SH-60B's Avatar
SH-60B
No secret but brute force. Could wire brush and lube the theads from under the car.
Old Jun 13, 2016 | 06:04 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Kroil
Try spraying the bolt with Kroil. Soak it every day for a week.
They get pretty corroded exposed to the road grove.
Bob K.
Old Jun 14, 2016 | 09:42 AM
jim in oregon's Avatar
jim in oregon
I lubed my bolts both the two down on the pan and the one behind the seat under the trim cover with PB Blaster..Left overnite.You must have the proper TORX bit andfit it into the bolt head snugly and completely.. A strong socket wrench and perhaps a cheater extension give extra leverage.
Funny but sometimes IF one applies force AS IF he wanted to tighten a froze bolt..and THEN exerts force to loosen it, it'll break free..The pros use an air impact wrench..Jim
Old Jun 14, 2016 | 11:21 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Seat belt bolt
The seat belt bolt on my 66 stripped out. I ended up welding a nut on the bolt head. The heat from the welder and the added nut made short work of the bolt. It came out very quickly after that. Jerry
To remove seat belt
