headman headers
Old Sep 9, 2002 | 09:03 AM
78pace's Avatar
78pace
Default headman headers
looking at a pair of headman headers for my 78 question is: Will not fit with steering damper inside front cross member. is this some thing i need to worry about thanks
:confused: Specifications:
* Primary tube size: 1 5/8 in.
* Collector size: 3 in.
* Finish: Ceramic coated
* Not for use with smog injection or injection heads.
* Shorty-style header
* Will not fit with steering damper inside front cross member.
* Will fit with angle plug heads
[Modified by 78pace, 8:04 AM 9/9/2002]
Old Sep 9, 2002 | 11:30 AM
fauxrs's Avatar
fauxrs
Default Re: headman headers (78pace)
nope :) I've got a set of hedmans on my 78 as does SD-Pacecar obviously both of us have steering behind the front crossmember and they both fit - the Power Steering ram (if you have it) comes within an inch of the tubes however if that bothers you.
on the drivers side it looks like this
I did have one minor clearance issue at the idler arm on the passenger side and I did have to dimple the tube for clearance around it as can be seen here.
other than that these fit terrific. Another tip (only works if you have a manual) is the header extensions from Hedman - these are s-bend pipes that mate with the header. If you cut off the collector from the header extensions (s-pipe) and add a short straight section at the header collecter - they will perfectly match the holes in the frame.
I used that space to add an h-pipe that runs under the transmission - again you only have room for this if running a stick.
Old Sep 9, 2002 | 11:37 AM
Twin_Turbo's Avatar
Twin_Turbo
I think it says will not fit non power steering cars with a steering damper
Old Sep 9, 2002 | 11:39 AM
Fevre's Avatar
Fevre
Default Re: headman headers (Twinnie)
Exactly what does the dampner do and is there any benefit to them? Wonder why GM quit putting them? :confused:
Old Sep 9, 2002 | 11:48 AM
fauxrs's Avatar
fauxrs
Thats a good point - I always thought the manual steering damper was more or less the same size and location as the power steering ram. Is that not the case? In truth I've never crawled under a manual steering car to look at that but it seems to me that they would use the smae mount to frame and the same center link (where the ram attaches) so unless the damper is considerably larger in diameter than the PS ram I would think it would work.
Again anyone with picts of the Damper would be very helpful right now.
Old Sep 9, 2002 | 02:44 PM
Tominator's Avatar
Tominator
This probably doesn't help but here is a picture of them on a 76
[Modified by Tominator, 12:48 PM 9/9/2002]
Old Sep 9, 2002 | 03:14 PM
Chris69's Avatar
Chris69
Default Re: headman headers (fauxrs)
fauxrs... Are yours shorties and do they have 3" collectors? You have the part number handy (with the air tubes)?
Old Sep 9, 2002 | 03:36 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: headman headers (Fevre)
The dampener is there to dampen steering movement caused by irregularities in the road.
Old Sep 9, 2002 | 03:37 PM
Fevre's Avatar
Fevre
Curious to what is feels like as compared to no dampner like mine. Seems it would make it a little harder to turn.
Old Sep 9, 2002 | 03:59 PM
fauxrs's Avatar
fauxrs
Default Re: headman headers (Chris81)
Nope - mine are just like Tominator's above with air rails the p/n is 68301
Old Sep 9, 2002 | 09:54 PM
Chris69's Avatar
Chris69
Tnx. Do you recommend their HTC coating?
Old Sep 10, 2002 | 01:47 AM
fauxrs's Avatar
fauxrs
The look is good with no blueing or burning off - so for that reason alone its worth it - but the price is awful high IMO -I was fortunate and got mine for a real good deal from a Forum member on E-bay.
Old Sep 10, 2002 | 07:28 AM
Graemeinvette's Avatar
Graemeinvette
I have hedman Headers on my 70 with power steering and there is no problem of clearance. Do not remove the steering damper though, nthey serve a good purpose. :cheers:
To headman headers
