reducing exhaust noise
Old Jul 4, 2016 | 04:04 PM
Belgian1979vette's Avatar
Belgian1979vette
Default reducing exhaust noise
I have a noise issue in the sense that the exhaust can get really loud at times and it's virtually impossible to enjoy a radio in the car.
Now, I do not have the easiest of engines in this regard and my exhaust consists out of a dual ss exhaust of 3" with bullet style mufflers under the seats and a Magnaflow straight through muffler in the rear.
The sound of the exhaust as far as the tone is concerned is great.
I just have the impression that the exhaust is bouncing off the walls of the rear compartment, creating a box like effect.
Any solutions ?
Old Jul 4, 2016 | 04:10 PM
zwede's Avatar
zwede
Well, dynamat style insulation will certainly help. Especially on the rear wall of the tub.
Another thing to keep in mind is that the longer the case of the muffler, the lower the volume (all other things unchanged). A 18" straight-through muffler will be quieter than the typical 14".
You already have an X-pipe, I hope?
Old Jul 4, 2016 | 04:19 PM
Belgian1979vette
Yes, under the rear axle
I'm not quite seeing why the rear compartment would reflect the noise that much with a rear exit exhaust.
Old Jul 4, 2016 | 05:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
larger case turbo style wil quiet it down some
Had bullets never cared for them seemed to make thigns worse
Cockpit acts like a speaker box
cant help but think the pipes transmit harmonic frequency throughout the car, the pipes vibrate. Wondering if clamping some type of dampening material over a given section of pipe couldnt dampen that and help out somehow.If you think about it its a long piece of pipe that vibrates, that has to contribute to interior noise/resonance outside pure exhaust note
Old Jul 4, 2016 | 08:01 PM
qwank's Avatar
qwank
Bigger amplifiers for you speakers
Old Jul 5, 2016 | 12:43 PM
MelWff's Avatar
MelWff
get rid of the bullets and install these in the back
http://www.dynomax.com/dynomax-vt-of...red-17157.html
Old Jul 5, 2016 | 02:13 PM
zwede's Avatar
zwede
I had those, but they started rattling after less than a year.
Old Jul 6, 2016 | 10:59 AM
jim-81's Avatar
jim-81
I'm no expert but I have the Corvette Central system which has a cross over, true duals, and Magnaflows in the back. I replaced the Magnaflows with smaller ones to make it a little louder. The sound is great, deep and low. I don't know why you would have another set of mufflers under the seats/cab. Maybe there is a good reason.
Jim
Old Jul 6, 2016 | 01:14 PM
Belgian1979vette
Jim
Engine was way too loud without them.
Not the average engine under the hood.
Old Jul 6, 2016 | 01:29 PM
Magna_Flow's Avatar
0Magna_Flow
Former Vendor
Larger mufflers will help bring the volume of your exhaust down, and laying dynamat, or another sound insulator will help reduce cabin noise. In our experience, placing the sound deadening behind the seats and in the trunk was most effective, though some people go as far as doing the entire body.
Old Jul 6, 2016 | 03:52 PM
Belgian1979vette
A question : is this sound waves bouncing back off the ground and back to the body or is this eminating from the pipes themselves;
BTW : my mufflers are 14" ones. which were the max I could comfortably fit under the car in the rear.
Old Jul 6, 2016 | 04:13 PM
zwede's Avatar
zwede
Why? I fit 18" case mufflers with no problems on my '71.
Old Jul 6, 2016 | 05:25 PM
Belgian1979vette
Any bigger and the curb leading the 3" pipes into the muffler would end up against the tire.
Guess the big pipes and their radius are to blame.
Old Jul 6, 2016 | 05:34 PM
zwede's Avatar
zwede
A picture would help. My 2.5" pipes are no where near the tires. You're using offset-in/center-out mufflers, right?
Old Jul 13, 2016 | 05:35 PM
Belgian1979vette
Should take a look, but I think center in, offset out.
Old Jul 13, 2016 | 07:06 PM
zwede's Avatar
zwede
Sounds backwards unless they changed it between my 71 and your 79.
Old Jul 14, 2016 | 05:07 PM
Shark Racer's Avatar
Shark Racer
Zwede - are you running a spare tire?
To reducing exhaust noise
Old Jul 14, 2016 | 05:42 PM
zwede's Avatar
zwede
Yes.
Old Jul 15, 2016 | 10:44 PM
ram82fire's Avatar
ram82fire
Yes.
what is the id of your tail pipes
I think I may have a remdy for your noise problem
gman
Old Jul 16, 2016 | 03:09 PM
Belgian1979vette
This is what I found fit best. The muffler is angled so that most of it stays behind the bumper and only one side is more or less visible. Other option would have been to angle the tips down, this would have let me use a center out.
