Quadrajet rebuilding
I keep coming back to the qjet might just be what I want but in that comes all the cons ranging from a good core to being at the mercy of one of the qjet gurus,
I was looking around the net qjets do they have their stigmas but people do actually rebuild them themselves with success,
on the qjets but the veil of mystique is lifting for me, I plan to order cliffs book, I have rebuilt more solex than I care to recall and while pretty darn simply compared to the qjet I believe I will tackle it.
I found this low end rebuild
http://www.vetteprojects.com/kstyer/quadrajet.htm
It doesn't address some important issues like leaking shafts or things that need to be sealed but it is down to earth ego free and shows what this cat did.
So have you rebuilt a qjet?
I would love to hear your story, success or epic fail, no judging just for the info on the subject.
And no, saying send it to lars or ruggles doesn't help any....
And naming some other make of carb you like better and or trashing the qjet isn't what this thread is for....
Thanks for the link!
No story yet but hope to have one with a happy ending soon!
And I will try anything once, or almost anything, after thinking about what is the worse that can happen???
So since my carb on my 454 68 Corvette has a mysterious past and believed to maybe be from an RV of all places, I upgraded to a 74 truck 454 q jet from ebay that needs to be rebuilt (ok, actually an upgrade for me, ha!), bought a rebuild kit, and bought Cliff's book. Having built a few Holley's and quite a number of outboard carbs, I am hoping I can follow the directions and have a reasonably successful outcome (I hope) with my first q jet. You might check out Lars' q jet papers too. Between Lars' papers and Cliff book, I think it is doable.
Please keep us posted on what you discover and if mine turns out to be a disaster, I will let you know, LOL's!
What I liked so much about the link is the fellow is just showing what he did what worked for him not all puffed up spewing.
Do you guys like cliffs book?
I will also look at lars papers I would assume that they have to be close in what works
I too believe i can do it, I have done the solex i mentioned many import bike carbs, a few holleys and several edelbrocks then a weber or two even a Zenith that had a leather pump seal.
I really love the idea of the qjet and the big secondaries when we need them,
Since i have no core and a great looking core could be trash and a poor looking core could be good I believe i will try to find a good looking edelbrock qjet a lot of things like the shaft bushings will already be done.
I am hoping more people will chime in
Perhaps I am dead wrong.
Problem is such limited info out there on them but since I always liked edelbrock stuff I give their qjets extra kudus....
I see them posted on ebay and hit a vendor the other day,
I asked "would this be a good carb for a mild cruiser 454?"
3 days later I get the reply, "yes"
When I hit jet I end up on the phone for close to one hour with a kind tech telling me what to expect from this or that what is good for me what is too big etc....you know how that all goes.
It's hard to separate the hobbyist from the true gurus
The throttle shafts have to be pretty sloppy and worn to have a significant effect on vacuum loss. When you get the carb rebuilt and put it on the car, you can test for that if you have a concern. Warm car up, set at idle, and measure vacuum level. Then put Play-Doh or clay around the ends of the throttle shaft on either side to plug off any possible leakage between shaft and bore. If the vacuum level doesn't increase more than 1" Hg, ignore the leakage.
For bottom plugs, you should test for leakage to start. Take the disassembled carb body and pour some gas (or water) into the bowl. If the fluid leaks out the plugs, you need to seal them. If it doesn't, forget about it. If you need to seal them, I would drill out the existing lead plug and replug with JB Weld stick (cut & knead) epoxy. That should resolve any problem.
The only 'tricky' part to the rebuild is the reassembly of choke actuating arm to the choke rod. That arn fits over the choke shaft which extends inside the carb, and getting it all lined up can be a pain. If you need specific info on how to do that, send me a PM and I'll pass my method on to you.
Otherwise, it is a straight-forward deal to rebuild it. But you do have to determine if the carb you get has the rods/jets in it that came with that P/N. If so, chances are that unit has not been "abused" with any prior rebuilds; if the rods/jets are different, you may not know what you really have. Lars papers have lists of the rods/jets for Chevy Q-jets by P/N, so you can check out the carb you are working on AND rebuild it to specs for your '69 C3.
Finally, I'm not sure why sending your carb to Lars is out of the question. He is rebuilding carbs...if you request it via e-mail to V8FastCars@msn.com. Now, if you've "bad-mouthed" his posts in the past, he may not want to do it. That does seem to be a problem around here....
http://quadrajetparts.com/secondary-...lug-p-122.html
Well worth the $9 in my opinion.
got Cliff's book today and I am thinking you will earn a PHD in Qjets if you read it thoroughly. Great book! Highly recommend you get a copy.
also I read Lars stuff, numerous pages of great info and tips too, thanks!
(Out of curiosity, and no intent to commandeer Bats thread, but what is downside of installing a truck 454 carb? For a Sunday afternoon cruiser, I am thinking it would work ok for that purpose or not? I suppose you might change out the metering rods as needed if you wanted?)
This is as good a place as can be to explain my take on this, I have never that I know of bad mouthed Lars but I have said things that very easily could be misconstrued.
I have commented that I do not want to be at the mercy of any one "guru" on any subject and more so on a rebuilt part, what if my part that only the one guru can work on has a problem and the guru is no longer around, I am hosed,
( This means I need to at the very least learn the basics )
I also do not believe that lars, ruggles or any one person is the end of the line and the end all to be all with in this case qjets, so just like with other topics here I do get a bit irked when threads are high jacked to push one brand or person,
I find that as a big dead end to real unbiased tech talk, I like posts and offers like yours that for example you found the choke tricky and are happy to help with the way you tackled it.
Bought the Doug Roe Rochester Quadrajet book, and followed the directions. It ran pretty good, and I was pleased for a first result novice. Shortly after I bought a really nice core (with a whole car under it) and built that according to the book. That carb is still on that car, and runs great. After several hundred thousand miles, I've rebuilt it a few times, had it rebushed once, and it still fires up easily and runs wonderfully. I have them on all of my carbed Chevys and on a 351W in a 71 Mustang, too.
Don't be afraid of a Qjet, find a nice core (or 2 or 3), get the books, and take your time building it. You have the skills.
Good luck,
Tom
Holleys work great for many, some of us don't want one. We're discussing Qjets here, and what to do to make them thrive.
