Quadrajet rebuilding
I have a Cliffs rebuilt QJet ready to go on my Camaro. Kinda excited to see how it will run.
Once you have the QJet dialed in it's pretty much worry free. For pleasure driving .
It's not like you have to rebuild it every other year . It should last the rest of you life or till you can not drive.
Just pay Cliff to build it how you want and be done with it. According to your engine spec , trans , rear end , etc.
You have a chance to get one of the best to build you a QJet . He won't be around doing this forever .
If you are not familiar with the APT screw system on the 1705xxxx carbs, it is pretty genius. I would recommend one of these for the tunability aspect. I have the 17058204 like the one Shark Racer built here https://www.corvetteforum.com/forums...t-rebuild.html
Basically, you swap primary jets to set your WOT air fuel ratio. At WOT, only the rod tip is in jet so the variable is the jet size. (beauty of a qjet is you can swap the jets with the carb on the car and without disconnecting the fuel or spilling a drop.)
Then you need to gain access to the APT screw to dial in your cruise or part throttle A/F ratio. This screw raises and lowers the lowest setting for the rods. Under high vacuum, the rods are pulled down so that the tappered part of the rod is in the jet. The APT screw allows you infinite adjustability. Its like an idle screw for the mains.
So its easy to adjust the mixture for altitude, winter, summer, or fuel economy.
I would give Cliff a call. The first thing he said was (as 7T1 said) my carb was calibrated lean. The fix for that was to tap in air bleed restrictors. He has the kit you need including the following special items:
* custom lathed rods
* air bleed restrictors
* APT port access plug
John
I've looked at all the cores on eBay. NOTHING listed would be more preferable for your car's needs than that '69 carb. Most of the rest of them (under $100) are junk that you will have to purchase at least one more core carb to make a 'good' complete unit.
Do what you will. I just hope you won't be sorry...for a mere $50 difference.
again thanks all,
And it goes to show that the mystique and opinions surrounding the Rochester qjet will be longed lived, even which year ones are the best cant be agreed on in this little thread...
I hate to say it but yeah, when my car is running again many parts like the carb will likely out last me,
But where I gave the impression I am playing this cheap I do not know while I make fun of my budget build status I will pay between 4-500 for a top name rebuilt unit, ruggels, murphy, jet not sure which one but all agree and do many things most of the smaller or hobbyist re builders do not do,
I will also pick up cliffs book and a few cores but where I get them isn't about being cheap or a 50 buck difference but rather the fact that most agree with that all qjet cores are hit and miss and unless you buy it from a guru or are savvy and break it down at the sellers house there is simply no way to prove a 100 eBay core is automatically better than the cheap or free some one gives me,
I am excited about this and it's very motivating.
Sometimes you can glean that info from the seller or the ad; or you can ask the seller whether it has been rebuilt or not. If the original owner is the seller, you have a good shot at getting a good core.
This is a great example where I am good surfing coat tails and asking each big rebuilder what they recommend,
Also in 69 was the same qjet on sb and bb's?
One thing I am seeing is most of the big names for the most part agree what is what yet step down to the ones I respectfully call "hobbyists" and they seem to each have a different opinion,
ANY 1969 Chevy Q-jet would be a good candidate for ANY 1969 Chevy vehicle.
Why do I say they're easier to deal with?
1. APT, as mentioned. This makes tuning cruise much easier.
2. More reliable - GM figured out most of the problems by then.
3. On-carb choke, anyone who's set up a divorced choke knows how much fun that is. This opens you up to using pretty much any intake manifold you'd like - as long as it supports a spread bore or you have the space for an adapter (not ideal).
4. They're dirt cheap because most people think the 4Ms are better since they're from the "performance era". They both flow 750 CFM, with some of the M4Ms actually flowing 795 CFM.
17080204 = 350/190hp AT
17080207 = 350/190hp ST
17080228 = 350/230hp AT
80 was the first year for the E4M, but CA only. M4Ms started in 1975, but the 75 carbs have some extra circuits that make them more complex, so more specifically I'd look for 76-78 carbs. 79-80 have different idle mixture screws (and passages which necessitate the screws) which require a different different screwdriver bit (DD, I believe). The earlier M4Ms us a combination head, you can get at them with a slotted screwdriver or a 1/4" socket. A 1/4" socket on a flex head makes them very easy to tune idle with.
Functionally, they'll behave the same (have the same level of reliability and use the same parts to tune otherwise).
You can tell an M4M from the top because they'll have two major clues:
1. The choke flap has a wide notch in it that looks like a "D" with an "O" towards the center of the "D" to fit the casting rather than a much narrower "O" shape.
2. There is a 3/8" steel dowel plug in front of the choke flap that blocks access to APT. In the carb I photo'd above, I removed the plug and tapped the hole for a 3/8-16 set screw so that APT can be adjusted without removing the airhorn.
Here's a pic of a 4MV for comparison:
I also think those folks in CA only got a 305 back in 80?
Cliff's book agrees with Shark Racer: 1976-79 large bore with appropriate inlet placement (front or for Chevrolet, side inlet) are the practical sweet spot.
I'd put my preference list for Cores as something like this (and all Chevy Cores, BTW):
1. 76-78 M4Ms
2. 79+ M4Ms
3. 4Ms - but at this point there's a BIG gap between 2 and 3 in terms of desire.
4. E4Ms.
I agree that sockets can be bought or made, but 1/4" hex is such a more common socket and pretty much everyone has one, not to mention they're commonly used as the shank size for most replaceable bit screwdrivers. And you have 6 different ways to get the orientation right vs 2 for a DD. IMO, they're also more positive "feel" on the turning so you're better to appropriately feel the 1/8 turn finesse you need for adjusting idle mixture screws.
But not a dealbreaker.
Other clues for an E4M are the TPS plug and idle air valve.
http://www.bing.com/videos/search?q=...8C7E&FORM=VIRE
Hope this might help.
