Vin Number replacement
Old Sep 10, 2002 | 07:51 PM
Blane Johnson's Avatar
Blane Johnson
Default Vin Number replacement
I have a 1969 corvette.The vin Number is hanging on by one side. Does anyone know where to get a replacement . Thanks, Blane
Old Sep 10, 2002 | 08:32 PM
72GACRZR's Avatar
72GACRZR
Default Re: Vin Number replacement (Blane Johnson)
Be careful. You can't get a replacement due to legal situations. Try to repair it with original type fastners. Nolan Adams has written a couple of articles about vins, it was in either Corvette fever or Vette Magazine I think, sorry can't remember which. try search of archives or corvettefaq site for other threads.
Old Sep 10, 2002 | 10:17 PM
tnt76vette's Avatar
tnt76vette
Default Re: Vin Number replacement (72GACRZR)
A VIN # cannot be altered w/o penalty of law. VIN #'s where I work (GM Lake Orion MI) are computer scanned b4 installation and unused ones are locked up in a safe at days end, for use the next day..... :yesnod:
Old Sep 10, 2002 | 10:43 PM
Solidlifters
I've never seen one broken on a 69, but here's a suggestion: Remove the cover on the left windshield frame. If the vin tag is loose on one side, pry it up enough to sand the back of the tag and the post and put some two part epoxy behind it and hold it in place until it dries. The repair shouldn't be visible when the cover is back on.
Old Sep 10, 2002 | 10:57 PM
lbell101's Avatar
lbell101
I understand your delema. From two of your posts, I think you are replacing the windshield frame and need to transfer the VIN tag?
OK, first - it's illegal to do that yourself. As I understand it, what you are supposed to do is have a cop look at it and supervise the transfer. BUT I've heard some real horror stories about this. Including confiscated cars and State issued replacement VIN numbers.
What I would do is buy the correct rivits, make the transfer (leaving the old paint under the tag), finish my windshield frame fix, and never tell anyone. That's illegal but it's not immoral - IMO. This is not a suggestion, it's just what I would do.
If you are looking to have a new VIN tag made, I doubt you will find a manufacturer. Making them is illegal.
Larry
Old Sep 10, 2002 | 11:48 PM
NHvette's Avatar
NHvette
Default Re: Vin Number replacement (lbell101)
I think - from the varied responses that I've seen on this - that the
situation varies from state to state. In NH, a VIN tag that has no title, due
to age, must have the VIN # verified (by reading it) by a state inspection
station OR law officer. A form is filled and signed - and I presume that the
VIN # is run for stolen/etc after registering it.
Luckily, my tag stayed attached for all my repairs - so re-attaching it was
not an issue. If you do attach it yourself, you might be able to take a file
to a steel pop rivet, making a roset type. You mght be able to buy some,
but I hear they are expensive.
Good Luck !!
Here is what I did last night:
http://webpages.charter.net/davekimt...S/P9100001.JPG
http://webpages.charter.net/davekimt...S/P9100002.JPG :seeya
Old Sep 11, 2002 | 09:41 AM
MassVette's Avatar
MassVette
No, but you can buy the star rivets at:
http://www.trimtags.com
:yesnod: :chevy :chevy :yesnod:
Old Sep 11, 2002 | 02:22 PM
72GACRZR's Avatar
72GACRZR
:bb Iwas wrong with both mags, it's Cars & Parts Corvette June 2002 and follow up in October 2002. Nolan lists Bill Clements in Lubbock, Texas at 806-747-4848 as the source for missing vin tags. For your situation, I guess you need to check on the local laws.
Old Sep 11, 2002 | 03:31 PM
Ki m Le's Avatar
Ki m Le
Blane, at least your is not rusty as mine. I've been looking to restore the VIN tag on my 69 for few years now. So far, no luck.
[Modified by Ki m Le, 2:31 PM 9/11/2002]
Old Sep 11, 2002 | 11:05 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Hi, I'm a Deputy in Tennessee. No I don't take care of this type of problem but my friend does. He is a Criminal Investigation Agent for the Tennessee State Highway Patrol. This is his job.
In TN I have personel knowledge of a man that took off his plate and then called to have it "Re Riveted" and it was confiscated and replaced with a Rebuilt VIN Plate. (Not by my friend)
I didn't agree with it and would n't have done this to the guy because it was a legit car that only needed the windshield frame replaced.
I think if he had waited before removing the tag and had it inspected and then asked to have it removed and then replaced by the agent it probably would have been done the way it should have been.
I would consult with my local agency and ask what should be done to circumvent any problems and more than likely you will be helped out.
ANY VIN swap is ILLEGAL in any state as far as I know at this time.
Do it the right way and you will come out way ahead.
As a last resort if it's just loose, shoot a little glue under it, JIM :seeya
Old Sep 12, 2002 | 12:18 AM
bn7035's Avatar
bn7035
Blane, In Texas it is unlawful to alter any serial number or VIN. If the police have proable cause to believe the VIN is altered in any way, your vehicle is subject to seizure. Your vehicle will be returned to you if all the secondary VINs are OK. But then you'll still be out towing and storage fees for a couple of days. If it is obvious you may find yourself eating breakfast at the local jail. Posting tips on how to restore VINs is alot like posting how to make VIN swaps. Enough people are enguaged in that business and I would like to keep my insurance rates down. You can get a new VIN issued by the state but it is generally unwanted by collectable car owners. Sort of like rebuilt titles. I would gently try to put it in place and place a drop of glue under it to hold it there. Don't remove the rivet that is there. Most of the state troopers have a real good idea of what type of rivet should hold the VIN plate in place. There are subtle differences that most people are not aware of.
Old Sep 14, 2002 | 01:28 PM
WESCH's Avatar
WESCH
Default Re: Vin Number replacement (bn7035)
Hi all.
This is completely different over here in Europe, at least in Luxembourg.
They don't worry about any riveted on VIN plates or so, the VIN number must be stamped in a visible place onto the steel frame.
When we import US cars, the importer or the registration place will stamp the VIN number ( luckily the correct one from the paperwork of the car ) normaly onto the frame rail above the R/H front wheel.
The windshield post VIN tag is completetly disregarded.
Different countries, different ideas ! Our officers work mainly with paperwork and keep their hands clean.
:lol:
But don't misunderstand me , this is our legal way and I strongly suggest to find out your state's rules on this B4 manipulating the plate.
Good luck
Gunther
Old Oct 8, 2015 | 11:02 PM
tcsracing1's Avatar
tcsracing1
I have a very rusty vin tag. it is pretty much dust.
Car is being restored and has a reproduction tag but it is not original style.
Would like to get original style if possible.
Old Oct 9, 2015 | 04:18 AM
Ibanez540r's Avatar
Ibanez540r
Not sure if many of these guys are left to respond from almost 14 years ago
Old Oct 9, 2015 | 08:25 AM
Alan 71's Avatar
Alan 71
Hi TCS,
The first question is to determine just what you have now and where it came from.
Is it a "Replacement Tag"…. installed by a government agency because of something thing that occurred in the car's past history?
Is it a "Reproduction Tag"…. that someone else made to replace the original tag for some reason? (This continues to be illegal.)
Is this car presently titled and registered and is there any mention of this 'reproduction tag' in that paperwork.
Legitimate Replacement Tags generally look nothing or very little like original VIN tags on purpose.
Regards,
Alan
Old Oct 9, 2015 | 09:55 AM
anesthes's Avatar
anesthes
Originally Posted by Alan 71
Hi TCS,
Regards,
Alan
An Altered VIN (reproduced) is perfectly legal as long as it's documented.
Typically, you would tow the vehicle to DOT with the blue form, and DOT will complete the blue form indicating if the VIN was Original, Missing, or Altered.
As long as you don't SWAP vins, which is illegal
-- Joe
Old Oct 9, 2015 | 05:02 PM
Alan 71's Avatar
Alan 71
Hi Joe,
"An Altered VIN (reproduced) is perfectly legal as long as it's documented".
That's not my understanding at all.
A car either has the tag that was installed on it at St.Louis or one PRODUCED and INSTALLED by a state agency.
I've never seen a car with a "reproduction" VIN tag.
Regards,
Alan
To Vin Number replacement
Old Oct 10, 2015 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by anesthes
...An Altered VIN (reproduced) is perfectly legal as long as it's documented...
Not in my state.
Old Oct 10, 2015 | 10:04 AM
tcsracing1's Avatar
tcsracing1
Hi TCS,
Regards,
Alan
it is my fathers car from 1969... The windsheild was so rusty that the VIN was rusted to nothing.
A replacement tag was made during the windsheild restoration.
It is a legit car, and in canada. GM Canada documention and clean title with history all the way back to 1968.
Old Oct 10, 2015 | 07:40 PM
anesthes's Avatar
anesthes
Hi Joe,
Regards,
Alan
I suspect every state is different.
-- Joe
