Need headers help- angle plug heads
Old Jul 21, 2016 | 09:30 PM
crazydad42's Avatar
crazydad42
Default Need headers help- angle plug heads
Installing a 400 small block in my 82. Heads are Edelbrock with angle plugs and I can't seem to find headers that will fit. Suggestions??
Old Jul 21, 2016 | 09:49 PM
bluedawg's Avatar
bluedawg
Try calling summits tech line or email their tech department. if that don't work, try Lemons headers..
Old Jul 21, 2016 | 09:51 PM
crazydad42's Avatar
crazydad42
Called...no options
Old Jul 21, 2016 | 10:12 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
The Summit brand headers fit. I had the same issue. Have a look at this thread:
https://www.corvetteforum.com/forums...gle-plugs.html
Old Jul 21, 2016 | 10:16 PM
croaker's Avatar
croaker
I called they recommended Flowtech $316 Ceramic. I did have to call a couple of times to talk to someone who actually knew what they were talking about. I was looking at the Summit brand but they weren't sure.
Old Jul 21, 2016 | 10:18 PM
crazydad42's Avatar
crazydad42
Perfect! Thank you
Old Jul 21, 2016 | 10:23 PM
crazydad42's Avatar
crazydad42
Default Ceramic vs ceramic header wrap
Opinions on what's better, ceramic headers or steel with the ceramic wraps?
Old Jul 21, 2016 | 10:45 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Most of the headers available have lousy ceramic coating that doesn't last. You are better off buying bare steel headers and having them done by another coater. Calico Coatings and Caps Brite Hot Coatings are two that come highly recommended.
Old Jul 21, 2016 | 11:08 PM
Metalhead140
Old Jul 21, 2016 | 11:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
skip the wrap
make sure and coat them inside and out
Old Jul 22, 2016 | 12:54 AM
bluedawg's Avatar
bluedawg
Called...no options
www.lemonsheaders.com
Did ya call dan, i know he's got options but not cheap.
Old Jul 22, 2016 | 04:30 PM
v2racing's Avatar
v2racing
My Brodix -10 heads have angled plugs and raised exhaust ports that further complicate clearance for the plugs. I run Hooker Super Comp headers. It requires shorty plugs and I had to clearance the #6 header tube for the plug. Measured carefully and then took a round 3/4" steel bar rapped in a rag and laid in on the tube at the proper spot and angle and hit it with a large hammer. It made a nice indent and looked like it was made that way. It gave me the clearance I needed. It didn't even crack or mark the ceramic coating.
To Need headers help- angle plug heads
