Installing wiper actuator- dimensions ?
Old Jul 27, 2016 | 11:12 AM
Tim Ware's Avatar
Tim Ware
Default Installing wiper actuator- dimensions ?
Restored my wiper vacuum seals & now want to re-install the actuator. Of course, I did not measure the threaded distance for the lock nut before replacing the seal. How do I know how far the actuator rod should be inserted into the long nut to allow correct opening & closing of the door ?
Thanks for your help, Tim
Old Jul 27, 2016 | 11:28 AM
Alan 71's Avatar
Alan 71
Hi Tim,
The 'Assembly Instruction Manual' almost always has the answer.
Regards,
Alan
Old Jul 27, 2016 | 12:55 PM
mikem350's Avatar
mikem350
Alan...you RULE. as usual!!!!
Old Jul 27, 2016 | 04:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...The 'Assembly Instruction Manual' almost always has the answer...
Yep.
To Installing wiper actuator- dimensions ?
