I have a Chevy 350 that came out of a 1991 Chevy truck w/ 305 heads and stock crank/pistons in my Vette that is pretty low on performance. I'm also pretty low on my budget (Can't surpass $950 with heads. The cheaper the better).
Compression is 9.0:1, but should raise to 10:1 with smaller 64cc chambers
I'm upgrading the cam to a Comp XE274 hydraulic flat tappet which advertises a .490 lift and 274/286 duration
As for heads; I've been looking at scoggin dickeys modified 64cc high lift Vortecs
305 heads have poor flow and puny valves. If you just want to get your car up-and-running, those heads can do that. But, if you think that just raising compression number will get you better power, I don't think that's the case with those heads. Those 305 heads were designed for emissions purposes; I don't even think "economy" was on the minds of the GM engineers when they created them [let alone, "performance"].
Personally, I think you are better off with the stock heads you presently have on the car now. You might want to recurve the distributor for "performance"; that should net you about 25 hp, if you haven't optimized the distributor yet.
Well no; the point is that my engine currently has some fairly shotty 305 heads that I'm looking to change out to either Scoggin dickey's Vortec or Promaxx as shown in the OP
Run the Vortecs.......but remember that you will have to buy an intake for these......
I am not convinced that the ProMaxx stuff is quality....
Just my thoughts.....
The Vortec heads are a sure thing.
Another thing you can do is shop E-bay for used heads.....
I picked up a set of Dart Iron Eagles for $600 and they had very low hours on them.....
I've had really good luck with the vortecs, They do make a plane jane 350 into a powerful street cruiser, if you match it with a nice cam....i might step it down one from the xe274 to the xe268 for street cruising, especially if you run an auto trans.
These heads, a Performer RPM intake, some headers, and a distributor recurve like GKULL suggested, and I'm sure you'll be smilin'
The Edelbrock E Street heads are on sale right now as well, $909 and free shipping, they'd fit in your budget.
As noted before, remember you have to change the intake to run Vortec heads, so budget the standard SBC heads at least $100 more than Vortec to compare apples to apples. Reuse the intake you have, buy better heads. That puts you in the park for the E Streets.
The ProMaxx actually seem pretty good since the new owners took over from Patriot, or so says the Interwebz....
Most engine guys will tell you the Vortecs are some of the best flowing heads GM ever made. Certainly for the price they seem like it. You could look for used ones maybe? Or rebuilt. That saves $$ if they're nice and have new car smell
STAY AWAY FROM THE PROMAXX HEADS!!!! Trust me, you will be better off spending the money here and not going the cheap route. You truly get what you pay for with heads.
Do you have any first hand experience with PROMAXX heads?
Seems like 305 heads had tiny combustion chambers didn't they? I don't remember.
Vortec's use non guided rockers also don't they? Need the whole package plus the intake.
The Edelbrocks seem good for that price.
As much as I hate to say it, some of the import stuff is gaining quality and folks are having good luck...but I can't keep up with all the similar sounding names (which is the plan when you're copying a copy) as to which ones are decent and which are junk. Seems like the biggest issue at times is the valves, springs, studs etc...not the casting. I've seen some BBC import castings that are really strong and nice as well as some junk.
I would give Chris Straub a call. He DOES keep up with it since he sells parts/components to many of the big name cylinder head and cam mfgs. He know's which is good and which to stay away from. I believe he comes up with some decent pricing in entry level aluminum heads also with good components included.
Another would be Chad Spier. He's got a line of low budget aluminum heads that he swears by and he does a lot of serious head work.
JIM
Reason: wef
