Solution to rough ride on lowered C3s
1) Solid mounted the x member which raised the diff ~ 3/4"
2) Installed VBP dual mount spring
3) Installed smart struts
4) Installed QA1 single adjustable shocks
What I found is the ride to be somewhat rough/bouncy no matter what setting I had the shocks on. An email over to QA1 indicated that anything less than 12.5" center to center starts to get into high damping rates which reduces the difference between settings and makes for a rough ride.
I measured mine at 11"...10.5" is end of travel! GM was not doing us any favors in how they mounted the shocks. I saw one solution where the individual pocketed the frame and moved the shock mount up an inch.
I went the other way and remanufactured the lower shock mount. This modification is reversible and more easily made by your average DIYer. Here is what you need:
Tools:
1) welder
2) Drill/bits
3) Jig saw
4) Grinder
Materials
1) 1/4" steel plate
2) 5/8 fine thread grade 8 bolts
3) Whatever size bolts needed for your shocks. QA1 was also 5/8"
Don't forget to put a flat on one side of the bolt so it slips through the knuckle. Though you cannot see it, there is another ear on the outer side of the shock for the thru bolt. I also trimmed the bump stops about 1" to compensate for moving the x member higher.
With the increased shock travel the ride is greatly improved. I have the spring on the 3rd hole and the shocks set at 7. I believe 3-7 will give a good ride on most roads.
With the steel spring that was in it the car looked like a 4x4
He was shocked and never heard of such a thing. I told him when he goes in gear the rear will drop, and during hard acceleration too.
I'm curious because I have the VBP 340lb mono rear and coilover front suspension and my ride is very compliant and not bouncy.
I knew a guy years ago with a falcon sprint with traction bars that hung below the rim,everybody warned him about it. Driving like a nut in an area being repaired with the sewer covers raised he hit one shot his car off the road onto a sidewalk across the median. Killed a 7 or 8 year old kid on his bicycle. If there was an upside to it that clown lost his drivers licence forever.after doing some jail time.
