2 bars in floor area
Old Sep 3, 2016 | 02:18 PM
colo69's Avatar
colo69
Default 2 bars in floor area
1970 corvette convertible, i see these 2 bars in the floor area under the dash, passenger side. Is this GM factory?
Old Sep 3, 2016 | 03:08 PM
69FASTFUN's Avatar
69FASTFUN
Factory for convertibles. They are there for frame flexing
Old Sep 3, 2016 | 04:04 PM
Alan 71's Avatar
Alan 71
Hi c,
69's right they were installed at St.Louis.
There were typically 4 braces… 2 on each side of the dash.
I believe they were added to reduce 'cowl shake' while driving more than frame flex.
Regards,
Alan
Old Sep 3, 2016 | 06:15 PM
1971WBY's Avatar
1971WBY
I recently read that these bars only appear in cars with air conditioning.
Old Sep 3, 2016 | 06:34 PM
Alan 71's Avatar
Alan 71
Hi 71,
You could be right.
I'm unclear as whether non a/c convertibles had the braces or not.
Regards,
Alan
Old Sep 3, 2016 | 07:31 PM
69FASTFUN's Avatar
69FASTFUN
Originally Posted by Alan 71
Hi 71,
You could be right.
Regards,
Alan
I know my 72 a/c convertible has them
Old Sep 3, 2016 | 10:06 PM
1Fordman's Avatar
1Fordman
My late build 68 without a/c has them.
Old Sep 4, 2016 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
All convertibles were supposed to have the behind dash reinforcements. AC was not required. For factory AC, the upper bar was a different part number to clear the AC.
Old Sep 4, 2016 | 02:51 PM
John 65's Avatar
John 65
My 69 convertible without AC had them.
My 68 convertible without AC did not have any, an early car.
Old Sep 4, 2016 | 03:18 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
My 70 convertible without AC has them also. I'm pretty sure it is a convertible thing.
Old Sep 4, 2016 | 03:38 PM
1971WBY's Avatar
1971WBY
Interesting stuff. My '71 big block convertible, without A/C, does not have them and does not have any evidence of ever having them. I suspect everyone is correct -- sometimes they were installed and sometimes they weren't. Or maybe they changed practice along the way. I don't want to ruffle feathers or start a debate about the pros and cons of NCRS, but for the sake of sharing information, here is what the latest edition of the Technical Information Manual (70-72) says on the subject: "On convertibles (and some coupes as well) with air conditioning, a pair of brace rods passes from a bracket on the transmission tunnel to the lateral windshield frame on the passenger's side and to the hinge pillar on the driver's..."
To 2 bars in floor area
