Break-in oil
Old Sep 3, 2016 | 09:40 PM
Duntov's Avatar
Duntov
Default Break-in oil
I have mostly decided on using Joe Gibb's Driven hot rod oil in my engine, but not sure about break-in oil. It's a new flat tappet cam, and was possibly thinking about their break-in oil as well.
Should I consider a different oil? I'm looking for something that is readily available, and can order this from Summit.
Old Sep 3, 2016 | 10:56 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I don't know if you rebuilt your motor or someone else did. If you rebuilt it then you would know if you coated the correct parts with the correct lube or not. If you did then nothing much is really needed. Most break in lube can't do much better than good oil. Plenty of vendors will sell you "the good stuff" though.
If you coated your bearings, cam and paste on the rings then just make sure drain that oil as soon as break in done.
Good luck.
Old Sep 4, 2016 | 12:38 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Talked with several HP machine shops in m y area last year when I was searching for Gibbs BR30. A few shops said they had problems when they used Gibbs break in oil. It seems there was a formula change and the newer stuff wasnt up to the task.
I elected to go with Comp cams break in oil since I was running their hardware. That way there would be no question on what was used during break in.
Last LS motors I did I used Amsoil break in oil for the first 100 miles.
My Olds 455 I used Amsoil break in oil
Drained that changed filters and refilled with Amsoil Zrod 10-30.
Old Sep 4, 2016 | 07:27 AM
jb78L-82's Avatar
jb78L-82
I used Driven breakin oil on my rebuilt 355 (June 2014) for a 30 minute break in (with a ROLLER CAM) followed by a short drive of full throttle accelerations from 2,000-4,000 RPM for about 5 times to fully seat the rings (per the builders instructions). Changed the oil/filter to Driven Conventional oil 15W-50 for the first 750 miles. Have run Mobil 1 0W-40 European Formula since then (full true synthetic) and the engine is flawless with zero oil issues.
Note: All Gen 1 engines should follow a breakin procedure whether flat or ROLLER CAM per my builders direction and also supported by various articles from oil manufacturers (including Mobil) who specifically mention that roller cams require a breakin just like flat tappet cams....I often see mentioned on the forum that roller cams do not require a breakin..not true.
Old Sep 4, 2016 | 09:59 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I'll just say that I did not use any break-in oils when I installed my retro roller because it was "not" required. Anyway, car is running fine after a few thousand miles.
Old Sep 4, 2016 | 02:13 PM
Duntov's Avatar
Duntov
It's got the lube on the bearings and moly type paste on the cam lobes. It was rebuilt twenty plus years ago, and hasn't been run. I have looked things over and things appear to be good still. Still planning on prelubing the heck out of it before the first firing.
Years past run a decent oil with GM EOS, for break in but with all the oil changes no clue what's best. Thought about putting a roller cam, but couldn't justify the $1k to do it.
Hoping to get the engine in this month and fire it up snotty thereafter.
Old Sep 4, 2016 | 04:25 PM
REELAV8R's Avatar
REELAV8R
Have you found why this is recommended? Many of us understand the process taking place when breaking in a flat tappet cam and that it is crutial to not getting a flat lobe.
What process is taking place while "breaking in" a roller cam?
Old Sep 4, 2016 | 05:49 PM
jb78L-82's Avatar
jb78L-82
The guy who did my bottom end told me specifically to do it and he knows a ton more than I do about breaking in engines since he does this for a living. I can ask him and he will have a very good reason but also this:
An article in Vette magazine a few years ago, titled, All About Oil which I still have and I quote here from the article,
"Flat Tappet engine builders are typically conscientious about using a proper, high- ZDDP break-in oil like Brad Penn grade 1 30 weight to protect internal components. However, some roller-motor owners mistakenly believe that their engines don't need break-in oil, In reality, without a purpose specific lubricant like Driven BR Break-In oil, those roller mills will suffer the same particulate contamination-and potential bearing failures-that a flat tappet engine would."
I base my statement on these 2 sources.
Here is more info from the article:
https://www.corvetteforum.com/forums...ch-2014-a.html
Old Sep 4, 2016 | 05:58 PM
DUB's Avatar
DUB
I use AMSOIL break-in oil.
DUB
Old Sep 5, 2016 | 11:48 AM
REELAV8R's Avatar
REELAV8R
This sounds like a general lubrication issue not specifically a break-in type failure.
I can understand using an oil that allows for the rings to seat. Other than that I can't understand how a roller bearing riding on a cam lobe NEEDS to have a break-in specific oil. I just used an off the shelf dyno oil that was not a fuel conservation formula with my roller and have not seen any ill effects due to that decision. Good compression, no oil consumption etc.
One of the advantages of roller lifters is the ability to take a lifter off of one lobe or cam and apply it to another lobe or cam. If there were some specific wear pattern achieved in a roller lifter this would not be possible.
So I would definitely be interested in what your mechanic has to say in regards to a break-in period for the roller cam. Always interested in what the pro's have to say, as they do this every day.
Old Sep 5, 2016 | 11:59 AM
jb78L-82's Avatar
jb78L-82
Pretty sure the answer is here:
http://www.onallcylinders.com/2015/0...ller-camshaft/
You need to use a break-in oil for roller cams with rebuilt engines not for the roller cam itself but the particle matter created by other engine components wearing in that can effect the roller cam (this reason was stated as well in my other source from Vette Magazine):
"While the rings need to be seated in a roller, an oil that “wears-in” the rings will create a lot of fine metal particulate, and that particulate is a killer for your roller cam. According to Timken, the number-one reason for premature roller bearing failure is particulate contamination. An engine creates more particulate wear metal during break-in than at any other time. In fact the “normal” wear metals for a new engine are up to four times higher than after a engine has finished breaking-in—hence the term “breaking-in.”
"Another aspect of roller cam break-in to consider is the high spring pressures and contact loads the cam, lifters, pushrods, and rockers see. While these loads would spell death to a flat-tappet cam, the high ZDDP anti-wear package of a break-in oil also protects these components during that critical break-in period"
The bottom line is pretty clear and why my builder highly recommended a break in for my roller cam...cheap insurance from problems down the road and why roller cams should be broken in just like a flat tappet cam.
Old Sep 5, 2016 | 06:19 PM
ajrothm's Avatar
ajrothm
I also use Joe Gibbs(Driven) oil. The last couple break ins I did, I used either BR30 or BR50. Both work well. I normally dump the first batch after the break in and some light engine loading. Then run the same stuff again for another couple hundred miles or so.. Then switch to whatever you want. I normally go to FR50 full synthetic.
Not a bad idea to throw a bottle of ZDDP break in additive as well.. I do...
Old Sep 5, 2016 | 08:46 PM
REELAV8R's Avatar
REELAV8R
Good article. It looks like they suggest running it like a flat tappet cam to get some amount of the ring wear in done and the particulate from the cylinders trapped in the filter. Then change the filter and oil and run it at higher RPM's.
I can understand this process. I suppose you don't want high RPM's until you change the filter so as to not bypass the filter and run the risk of contaminating the rollers in the lifters by re-introducing particulate into the oil or any particulate in the oil bypassing the filter.
Thanks Jb!
Old Sep 6, 2016 | 12:51 PM
cardo0's Avatar
cardo0
I'd have to look this up again but too much zinc will be counterproductive. It no longer acts as a protective coating. IIRC you want your oil zinc concentration something in the 1000-1200ppm range.
Old Sep 6, 2016 | 06:35 PM
DUB's Avatar
DUB
I agree with 'too much ZDDP is counter productive' You are correct.
But the levels of ZDDP can be higher than what you wrote...due to the AMSOIL Z-rod oil I use is higher than 1200ppm.....and the DOMINATOR racing oil is even higher than that.
https://www.corvetteforum.com/forums...st-data-5.html
POST# 95 shows a good list of oils.
DUB
Old Sep 6, 2016 | 07:16 PM
Shovels and Vettes's Avatar
Shovels and Vettes
While I typically try not to speak about things I am not sure about,......if break in is required on roller engines, then why is there no break in procedures written in my brand new car and truck manuals....and please, no conspiracy theories on the auto manufacturers want engines to fail.....because truth is, they don't. The manuals I have read typically just recommend staying under certain RPM's for so many miles, but none of the typical multiple step procedures that often show up on Forums.
And, interestingly enough, the recommendations for these stated are from the people who are selling break in oil!
I just find it all a little bit like trying to fix something that is not broke...but heh, what do I know. Its like pre-oiling an engine, it certainly can't hurt, but tell me this.....are NEW car and truck engines pre-oiled?
Old Sep 6, 2016 | 09:55 PM
Duntov's Avatar
Duntov
DUB
DUB, I read the oil thread and had over load on the oil choices and left more questions than answers. I'm looking for something that is mostly available and that leaves Amsoil or Joe Gibbs (Summit Racing Equipment).
To Break-in oil
Old Sep 7, 2016 | 02:07 AM
bluedawg's Avatar
bluedawg
I coat the cam and bearings, soak the lifterz and wipe down the cylinder walls with GM E.O.S assembly lube (bought from the parts room st the GM parts room)and add 1/4 cup to every quart conventional oil that I add to the engine for break in on a flat tappet cam and change to the intended oil after I break in the camshat. On a roller cams, i soak the lifters coat the bearings and wipe down the cylinder walls and swap at 500 miles.
Old Sep 7, 2016 | 06:38 AM
bashcraft's Avatar
bashcraft
There is no break in period for a roller cam. Just change the oil after the first few miles and it'll be fine.
Old Sep 7, 2016 | 08:31 AM
midigike's Avatar
midigike
AJ
Be careful with the additives added to break in oil, Mobil for example does not recommend any added ZDDP additive because it can screw up the oil formulation and cause harm. I know other oil manufacturers have this disclaimer too
