69 with dimples...need header bar
Old Sep 9, 2016 | 11:46 PM
RIO68's Avatar
RIO68
Default 69 with dimples...need header bar
My 69 has nose panel dimples...not taking it to Fathom Works lol!
got the old one out and have a replacement but it isn't near as thick metal wise as the original. Anyone had any problems with the replacement header bars? Leaving the original bonding strip in place and using 3M bonding agent to put it back no rivets ....appreciate any thoughts or experience???
Old Sep 10, 2016 | 10:17 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I have a spare header brace from a 69, it had some minor surface rust, no rust thru.
has been blasted and painted to protech, holler if you wish to purchase.
I basically glued and clamped the whole thing together, alignment is very important.
get it right the first time !
Old Sep 10, 2016 | 11:01 AM
zwede's Avatar
zwede
Bonding is the way to go. No rivets.
Old Sep 10, 2016 | 11:42 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Just be sure to remove (grind away) all traces of the corrosion from the original rivets before re-attaching the header bar.
Old Sep 10, 2016 | 12:24 PM
RIO68's Avatar
RIO68
Thanks guys--the old one came off pretty clean...according to the sheet Willcox put out I will need a small hole saw bit to cut the rivet heads from the bonding strip that is still there. Some of the heads pulled out but some cut or broke off and are still there. Part that concerns me most is the alignment issue...???
Any hot tip suggestions about alignment? Also, the 3M glue the best?
Old Sep 10, 2016 | 01:32 PM
69Vett's Avatar
69Vett
be absolutely sure you have removed 100% of the old rivets and corrosion.
Inspect every Old Rivet hole, they disenagrate, and the corrosion
likes to stay where it was, lodged into the fiberglass.
The surest alignment is drill a couple thru holes and use those for alignment when reattaching.
Old Sep 10, 2016 | 01:49 PM
John 65's Avatar
John 65
Here's the small shallow tool I made when I removed mine to get to the rivets.
It really worked great.
Before removing the support I drilled a few tiny holes through it into just the surface of the fiberglass. It made putting it back into the exact same spot easy.
I used an adhesive made by Lord-Fusor to re glue it. Clamped it all over the place into position and used wooden strips on the outside. When removed all the bumps were flat again.
Old Sep 10, 2016 | 02:44 PM
RIO68's Avatar
RIO68
That's great to hear the bumps went away!!
Careful is the word for the hole saw ...LOL Wished I had some guide holes but didn't do that. If the form of the new part is close to the original maybe getting it back in place might not be to bad...given the hole and nuts in it are right! What is the part number of the adhesive?
Old Sep 10, 2016 | 03:08 PM
zwede's Avatar
zwede
Install the headlight and make sure the lids are centered in the openings. That will tell you where the header bar needs to be.
Old Sep 10, 2016 | 03:45 PM
oldgto's Avatar
oldgto
I would NOT drill all the way through the outer layer.
Old Sep 10, 2016 | 08:48 PM
John 65's Avatar
John 65
By all means don't drill and come through the other side.
Lord Fusor makes tons of different adhesives. Dont remember the numbers but it was strictly for fiberglass to primed metal.
It was 2 tubes that went into a double caulking gun and mixed itself as it was applied. Solid as a rock.
Old Sep 11, 2016 | 09:33 PM
RIO68's Avatar
RIO68
[QUOTE=John 65;1593028798]Here's the small shallow tool I made when I removed mine to get to the rivets.
What size is the hole saw you used?
Old Sep 11, 2016 | 10:29 PM
John 65's Avatar
John 65
Its 7/8" wide.
Was a lot taller (longer) but cut it and had the cut piece welded back on.
Used with a small right angle drill to get up in there.
Old Sep 11, 2016 | 10:40 PM
RIO68's Avatar
RIO68
Its 7/8" wide.
Thank you...I don't have a 7/8 that short but may have to make one also. The trick will be not cutting through the top panel??
Old Sep 12, 2016 | 06:15 AM
oldgto's Avatar
oldgto
Right! Don`t cut through the top panel, only the bonding strip. I dug mine out with a chisel and razor knife.... but my front clip was off the car at the time.
When you re-glue, put a little extra into the dimples from the bottom, then clamp it with the boards and they`ll flatten out nice for you.
Old Sep 12, 2016 | 08:38 AM
RIO68's Avatar
RIO68
Thought about hand cutting them out...some pulled out complete, head and all others not so.
Good info...thanks!!
To 69 with dimples...need header bar
