thrittle cable alignment
Old Sep 11, 2016 | 12:40 PM
michaelroy's Avatar
michaelroy
Default thrittle cable alignment
Hopefully you can see in the pic where I put a new stud on for the throttle cable to attach. The prev. owner had a bubbaized stud and had the throttle and the rod to the cruise control in the wrong places (Swapped positions).
I need to pull the cable out of the bracket a little to get it in alignment with the stud. PROBABLE just a 1/4" or so. The plastic piece holding the cable in the bracket seem too large to slide out or to move at all.
Searched previous threads but could not find answer. Please advice needed.
Old Sep 11, 2016 | 01:30 PM
Street Rat's Avatar
Street Rat
I'm not much help if you are wanting to stay stock. I eliminated the factory cable and replaced it with a Lokar brand throttle cable and bracket. It solved my problems.
Old Sep 11, 2016 | 01:41 PM
michaelroy's Avatar
michaelroy
I could do that but I still wouldn't be able to get the cable out of the bracket?????
Old Sep 11, 2016 | 01:55 PM
bmotojoe's Avatar
bmotojoe
What year, always helps.
Old Sep 11, 2016 | 02:03 PM
Street Rat's Avatar
Street Rat
The throttle cable is retained in the bracket with an expandable plastic clip. Get some pliers and you can pinch the expanded portion of the clip on two sides. Pull forward some then slip backwards out of the bracket.
Old Sep 11, 2016 | 02:08 PM
michaelroy's Avatar
michaelroy
Sorry it's a 79 w/ cruise. I will try the needle nose plyers trick again. Will report back in a few. Thanks for the advise.
Old Sep 11, 2016 | 03:49 PM
michaelroy's Avatar
michaelroy
The plastic on the cable is wider than the slot in the bracket. I got it out but altered the appearance. Gotta b a better way.
Old Sep 11, 2016 | 03:55 PM
Street Rat's Avatar
Street Rat
Glad you got it.
Old Sep 11, 2016 | 08:28 PM
lvmyvt76's Avatar
lvmyvt76
anytime you start squeezing plastic with a set of pliers, you will change the looks of it!
To thrittle cable alignment
