Roller cam
To the poster. roller cams can use higher .050 duration numbers and still have higher vacuum and run smoother that their flat tappet counterparts
Roller cams should be broken in using the same procedure as flat tappet cams with a break in oil....Yes, the risk of failure is much less but do it right the first time and have piece of mind....And Yes the risk of failure from low ZDDP oils is VERY low but they still should be broken in............
We mostly use Comp's "-8" cams which allow the use of ALL the factory peripherals, like the dist gear and fuel-pump pushrod.
On a side note here we had a major breakthrough just recently in this area on these early builds. We just finished fabricating a method to install the later stepped-nose roller cams in the early units. So far it has been such a "positive" for us I'm surprised I didn't figure it all out much earlier in my life. Was actually fairly simple in the end.
Absolutely, positively, no more need for any cam buttons OR messing with cam end-play at this stage of building mostly retro-hyd rollers. Cam-buttons/shims, etc., is all in the history books for us. (See the photo below)
(Add) There is no break-in time required on ANY roller cammed units, you can start them up and "idle" away. We do recommend "soaking" the lifters overnight to get oil into the needle-brgs however!
Thanks, Gary in N.Y.
P.S. Here's a shot of the setup, using a 400" SB, we have dynoed 2 or 3 builds now with this modification, works flawlessly. First photo shows the plate mounted, second shows gear installed, .004"/.005" end-play accomplished easily! No buttons, no timing cover work, no headaches! Just bolt these rollers together now!
Car is fast though
however, on complete builds, the rings do need break-in The Best of Corvette for Corvette Enthusiasts
http://www.lingenfelter.com/PROD.htm...0#.V981qjMrKVM
We tore the 454 down and replaced the cam and removed the inner springs for the break in period and everything is fine.
Unrelated to breakin, but at the shop a customer brought in a Chevy suburban with about 85K miles on his all stock 454. GM factory H-roller on inspection nearly every cam lobe had roller wheel width tracks deep in every cam nose. So he was getting about 60% of his valve lift. It was a late 90's Suburban and maybe mid 2000 when it lost power. I think and this is when you first started hearing about EPA requiring clean oils with less lubrication factors.
I use VR-1 racing oil in both of my hot rodded roller motors
A retrofit roller cam and lifters is in my future so this sounds like a dream!
Adam
I have bought new vehicles, and read the manual, and all it says is to limit engine RPMS for the first so many miles....that's it. These are engines that routinely go 100,000 plus miles without issue.
So, so much for breaking in.
This may be one of those things were it is unsaid what is in the oil from the factory, but the assumption is that you don't run home, dump the oil, and put your own oil in, being as that would be a somewhat unreasonable thing to do.
There's no warning in the manual about not driving your car with your eyes closed. But that would also be a somewhat unreasonable thing to do.
There are some things associated with owning/driving the cars that simply aren't written in the manual.
I've owned a few cars from new, Nissan's I think, that stated the same thing in the manual to not change the oil before xxxx miles because it was an oil that had properties for breaking in the engine.
