Someone suggested ditching my Chilton's Manual and getting one of the assembly manuals offered by Corvette parts vendors. Apparently, the choices are more numerous than I have time to deliberate over which one is best. Can anyone suggest a good manual for a C-3, and why you like the manual you selected?
Hi g,
Knowing what year car you're asking about would help people refine their suggestions.
Generally what folks recommend are:
The GM Assembly Instruction Manual (AIM) for the year of the car.
The GM Chassis Service Manual for the year of the car.
The Owner's Manual for the year of the car.
These 3 are really a help in figuring out what's going on with your car and how to begin to fix it if it needs fixing.
Also, a good electrical schematic drawing and vacuum operations diagram are usually helpful too.
Good Luck!
Regards,
Alan
- Don't 'ditch' the Chiltons - it's always good to have multiple sources for information.
- Alot of people on here really push the AIM (Assembly Instruction Manual), and it IS a VERY GOOD reference, but contains no troubleshooting info - just alot of info (mostly just pictures) about how all the parts fit together. Definitely worth having on hand sometimes, but won't replace the Chiltons.
- for my 79, I bought the GM Shop manual. It is more similar to a Chiltons book, but goes into a lot more detail and usually only covers a single year. If you go to E-Bay, type in '19xx corvette shop manual' (replacing XX with your year) you should see some examples.
EDIT: Based on some of your prior forum posts, it looks like you have a 69. I think the GM service manual would be the one titled 'Chassis Service Manual' and covers Chevelle, Camaro, Chevy II, and Corvette. (you'll see mutliple ones for sale if you type in my search text above).
I think each manual has its place and there isn't really a definitive reference.
The AIM is more of a picture book but is invaluable. It's the starting point to figure out how it should have been put together and in what order. It does have some useful procedures like how to align the Windows.
The service manual is the best troubleshooting guide. It's specific to the year and provides procedures and torque values. Remember though, it was intended for mechanics.
Chitons (or Haynes) tend to be very detailed and idiot proof in their directions. Not every repair is covered and because their manuals cover many years and models, sometimes they're hard to follow. Sometimes they are just plain wrong.
Another trick that many on here use is the drawings in some of the parts catalogs. Just like the AIM, it'll help you figure out how it's supposed to be. With these forty year old cars, a lot of incompetent work has been done to them and undoing things that were done incorrectly takes more research and effort than just swapping out a worn out part.
Thanks, all. Surprisingly, or maybe no so, when I googled the manuals a multitude of images came up online. The car goes into mothballs for winter next month so will ask Santa for a couple of these manuals you recommend.
Hi g,
While there may be a multitude of images there really are just 2 or 3 of the books that you should start with. The AIM, CSM, and owner's manual for your specific year car!
Santa will be here before we know it!!!!
Regards,
Alan
I use the AIM almost exclusively. If I can see how something is put together I'm smart enough to take it apart. It also helps put something back together that you've had apart for a while.
I have the Chilton's and Haynes manuals but they are so generic that a lot of the instructions are not exclusive to Corvettes. I've noticed there are some diagrams and pictures in these manual that are NOT Corvettes. They usually stay on my bookshelf.
If you get the AIM also get the index. Although it's not impossible to find stuff in the AIM it does take some time figuring out how GM's AIM is layed out. The vendor supplied index makes it easy.
We offer a special from time to time for purchases over 100.00.. and I know you might not need anything right now, but if you purchase an order over 100.00 we'll give you the assembly manual on CD that is Optical Character Recognized and includes key search words.... For Free. It is the best AIM you can get.
If you do decide to place an order, just place a note in the order notes section that you want one and my guys will include it with your order.
Willcox
Willcox
Thanks for the offer. I can't wait for something to break, wear out, misfire, deteriorate, fizzle, fall off, or give out due to normal wear-&- tear. This is the best deal I've heard of in a long time.
