Turn Indicators slow when head lights are on....
Old Sep 21, 2016 | 12:24 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Turn Indicators slow when head lights are on....
Last night, I was driving around enjoying the "fall like" temperature in my convertible, when I noticed that the right turn indicator did not function properly...it came on and just stayed on...indication of a burnt out bulb. The left one worked...but kinda slowly. This morning I checked the right turn indicator and it WORKED PERFECTLY...right speed (on & off). BUT when I turn my head lights on, the indicator s-l-o-w-s down a lot!...turn the head lights off and "voila" they work perfectly!!! WHY??? and what can I do to fix?????
Old Sep 21, 2016 | 02:25 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by vetteguy75
Last night,...it came on and just stayed on...indication of a burnt out bulb. The left one worked...but kinda slowly.
This feels like your alternator having issues, your regulator is not regulating or your battery is not holding enough..
Headlights, dash light and markers suck the life out of an electrical system. The fact that your system operates normally during the day tells me that the night light draw is too much for your system.
Have the alternator, battery and regulator checked. My bet is you find your issue somewhere in the mix.
Old Sep 21, 2016 | 03:06 PM
65GGvert's Avatar
65GGvert
The very first thing I'd try is cleaning the ground connection on the radiator support for the front lights. Clean that ground very well and see what happens
Old Sep 21, 2016 | 07:30 PM
DUB's Avatar
DUB
I agree...it is more than likely a ground issue. And it can actually be at the light socket.
DUB
Old Sep 22, 2016 | 04:23 PM
Alan 71's Avatar
Alan 71
Hi v,
I believe you'll find one of the forward lighting harness ground connections that 65GG and DUB mentions on the front side of the core support just to the right of the radiator.
Hope that solves your 'issue'!
Regards,
Alan
Old Sep 23, 2016 | 12:50 PM
vetteguy75's Avatar
vetteguy75
To Turn Indicators slow when head lights are on....
