No Brakes
Old Sep 24, 2016 | 03:43 PM
Cigars4me's Avatar
Cigars4me
Default No Brakes
74 with power brakes. Pedal goes to the floor. Bled the brakes many times-no air in the system. Replaced master cylinder and added electric vacuum pump to make more vacuum. Still no pedal. Any ideas?
Old Sep 24, 2016 | 04:17 PM
Rodnok1's Avatar
Rodnok1
If pedal goes to the floor it's not the booster.
If system not losing fluid the MC is wither bad/wrong or needs bench bled as you have air or MC is bad.
Why did you replace all these parts and was there an issue before?
Old Sep 24, 2016 | 05:54 PM
DUB's Avatar
DUB
What method are you using to bleed the brakes???
Did you bench bleed the master cylinder correctly???
Did you check and verify the adjustment pin in the brake booster is correct to the previous master cylinder and the new one...especially if this problem was always present???
Does the pedal ALWAYS go to the floor...even when the engine is NOT running????
DUB
Old Sep 24, 2016 | 07:29 PM
Cigars4me's Avatar
Cigars4me
DUB
Pump, hold and crack bleeder. All air was removed, I'm sure.
I believe I bench bled the MC correctly.
Pin in booster was set at about 1/16 inch clearance.
Pedal goes to floor even without engine running.
Do you think the pro portioning valve could be bad? After all, it's 40 yrs old.
Thx, Bob
Old Sep 24, 2016 | 08:18 PM
Rodnok1's Avatar
Rodnok1
Bad Proportion valve wont cause this issue. Basically Its just a distribution block with a sensor that slides to a side if you have loss of pressure and sets the light off
MC is the issue, has air/needs bench bled again or just bad. Not unheard of to have new MC be bad out of box either.
Old Sep 25, 2016 | 01:00 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Thx, Bob
Pump, hold and crack bleeder. This should work but if the pedal is going to the floor there's no point in opening a bleeder cause You know something is wrong. The power booster has no bearing on brake performance all it does is reduce pedal pressure. Assuming You are working by Your self I'd take a long hose from any bleeder and run it back to the master. I'll bet You don't get any flow threw the hose at all. Reason being the master isn't pumping anything. Has the Master been dry at any point ? You can bench bleed the master, suck vacuum threw it or push fluid threw it with pressure to get it to bleed.
Old Sep 25, 2016 | 07:03 AM
Sluefoot's Avatar
Sluefoot
Didja bleed BOTH bleeders on the rears?? U sure the rubber lines at the back aren't collapsing? I replaced those, as well as the steel lines going from the rubber lines to the calipers....used stainless lines.
I bled my rears all by myself....used a jar w/ clear tubing coming from caliper into the jar so I could see the air or fluid coming out of calipers...I let the fluid gravity flow thru the caliper to ensure that the air was out of the system at least to the calipers first. Used a length of 2x4 to keep pressure on brake pedal against the seat.
I've had kikazz pedal ever since!!
Old Sep 25, 2016 | 10:07 AM
lvmyvt76's Avatar
lvmyvt76
its the M/C not pumping, rebleed it. is the rod the correct length, correct M/C for the car(you sure?) defective M/C. where did you buy the M/C?
To No Brakes
